2012 Idle adjustment - Road Glide Forums
post #1 of 19 (permalink) Old 11-20-2014, 03:51 PM Thread Starter
mouser58's Avatar
I called Vance and Hines, hoping I could adjust the idle on my Road Glide since I am using their Fuelpak, and of course, no... So I suppose I have to take to dealer?? It idles around 1300 till it warms up and then 1000-1100 when warm..
mouser58 is offline
post #2 of 19 (permalink) Old 11-20-2014, 04:20 PM
What's wrong with those #s ?
post #3 of 19 (permalink) Old 11-20-2014, 04:34 PM
JayKS's Avatar
Yep, sounds pretty normal.
The only way you're going to adjust the idle would be through a good tuner, like a Power Vision, TTS, etc. Even then, I've read that you'd be ill-advised to go much below 1000 rpm.
JayKS is offline
post #4 of 19 (permalink) Old 11-20-2014, 04:45 PM
+ what they said.
2011 FLTRX 103 Sedona Orange
Hillglide is offline
post #5 of 19 (permalink) Old 11-20-2014, 04:47 PM
Lowering the idle on your bike will starve the top end of the oil that it needs. This is a twin cam, not an evo. The traditional potato potato sound is not how a twin cam sounds.
HogPro is offline
post #6 of 19 (permalink) Old 11-20-2014, 06:24 PM
Normal idle is approximately 1000/1100 rpms. When mine starts cold it will idle around 1300/1400 rpms for a about 30 secs then will drop to normal. I too have the V&H fuel pak.
post #7 of 19 (permalink) Old 11-20-2014, 06:48 PM
Darreldanger's Avatar
Not so HD has the idle set for the EPA only.
Darreldanger is offline
post #8 of 19 (permalink) Old 11-20-2014, 07:30 PM
RoadGlideGary's Avatar
Sounds like you are normal. You can set it back to factory by turning igition to on and then the switch to run (no start) then repeat four more cycles. 1000 to 1100 rpm is good.
05' SuperGlideCustom - sold
RoadGlideGary is offline
post #9 of 19 (permalink) Old 11-20-2014, 07:40 PM
bucketlisthd's Avatar
For some mysterious reason, I have to reset my idle fairly often.
'15 Roadglide Special
'87 FXR 100"
'79 Goldwing cafe
bucketlisthd is offline
post #10 of 19 (permalink) Old 11-21-2014, 10:04 AM
I don't think EPA regs have anything to do with the idle setting.
HD sets the idle at 1000 to 1100 rpms because they have found that running the engine at a low idle will harm the top end because the oil will not reach the to end at such low oil pressure.
Also with all the electronics and lights on the newer bikes it is important to have the charging system put out more current at a idle.
I have a T-Max tuner and I can adjust the idle and T-Max suggest the idle can be set somewhere around 850 rpm but I still set my idle at 975 rpm.
2012 clutch adjustment cloud Tech Area 4 07-18-2012 09:37 AM
Idle vibration / cylinder unloading? hilltoptim *General Road Glide Discussions/Pictures 10 04-25-2011 10:59 AM
'11 CVO Won't Idle Easy Glider Troubleshooting for Road Glides 1 11-27-2010 05:02 PM
Shuts off at idle dgb road Troubleshooting for Road Glides 8 11-06-2010 10:18 AM
