Loading a new Map, Is it really this easy? - Road Glide Forums
post #1 of 6 (permalink) Old 08-06-2010, 01:38 PM Thread Starter
BillyBeards's Avatar
Is it really as easy as just hitting the send map button when loading a new map into my PC-V?
Thanks
Bill
2009 HD RG
BillyBeards is offline
post #2 of 6 (permalink) Old 08-07-2010, 11:21 AM
Shrug's Avatar
Thanks
Bill
Yes. I installed my PCIII and a friend's PCV with the USB cable attached and tucked into the fuse box for easy access. Downloading a map is simple. Just follow the instructions. Getting the right map might prove more of a challenge.
Shrug - Scott Wilson
2010 FLTRX "Hester 2.0" -
Shrug is offline
post #3 of 6 (permalink) Old 08-07-2010, 04:02 PM Thread Starter
I installed it during lunch yesterday and it seemed to easy to be true. I just wanted to make sure that was all it took so I didn't blow the whole thing up on the drive home.
The map is from Fuel Moto and seems to be running very well. Still a little bit of popping on decel in some spots but overall very good and I "think" I can feel the gains.
2009 HD RG
post #4 of 6 (permalink) Old 08-07-2010, 07:59 PM
Sancho's Avatar
Make sure you hold your mouth right when uploading a map. When you upload a new map make sure you save your old one before uploading if you haven't done so already. Hit 'save as' and give it a name.
If you call Fuelmoto they can probably get rid of that popping for you. I've never seen or had one that didn't pop every now and then. If it pops every time at the same rpm they can probably fix that for you.
Sancho is offline
post #5 of 6 (permalink) Old 08-07-2010, 09:42 PM
Thanks for posting this Guys
Mine is being set up now, I am putting in the PC V and will set a base and when I get the buck I'll spring for the Full on deal.
Frodoe is offline
post #6 of 6 (permalink) Old 08-07-2010, 10:30 PM Thread Starter
Yeah, I may have to send them an email because I realized it too late that I didn't save the old map.
So far I've only got about 20 miles on the bike since I installed the PC V but tomorrow I plan to get more riding in.
2009 HD RG
Installing just fairing speakers: Is it really this easy..? Rasconzo Audio 5 04-14-2015 10:02 PM
Trailer Hitch GVWR & Tongue Loading fragmentum *General Road Glide Discussions/Pictures 8 05-26-2013 08:17 AM
VIRUS Causing Loading Issues!!!! RGKen *General Road Glide Discussions/Pictures 4 04-14-2013 10:33 AM
Can it really be this easy glidethru *General Road Glide Discussions/Pictures 32 07-02-2012 02:53 PM
Ramp for loading your Glide into pickup truck Shark daddy General Off-Topic Discussions 21 04-13-2012 03:38 PM
