TTS Mastertune Map for 54H Cam - Road Glide Forums
post #1 of 4 (permalink) Old 11-30-2014, 09:48 PM Thread Starter
Hi all. Uncle's got a 2013 Streetglide and is putting in Andrews 54H cams. He has a TTS tuner and I was curious of where I can find a good base map for it. Any good sources?
saltydawg1967 is offline
post #2 of 4 (permalink) Old 12-14-2014, 10:21 PM
JetDe's Avatar
Yes, but---
Yes, but no... the one I have is for a 117" stroker with the 54h cam....
ran great, but the extra cubes and the larger intake and headwork will likely not be a great starter for your purposes. Hope someone has one closer.
2013 FLTRU 120ST SEST/PV-TT tuning underway
2010 FLHTCU 107" GMR built; PV tuned by me - gone
2007 FLSTC 117" GMR built; SERT/TTS tuned - gone
JetDe is offline
post #3 of 4 (permalink) Old 12-15-2014, 07:53 AM
FDR's RGC's Avatar
I'd try zippers
FDR's RGC is online now
post #4 of 4 (permalink) Old 12-15-2014, 08:15 AM
124shark's Avatar
I would suggest a 103 map like the DTQ 009 Allens/ Jet's map would not even be close. ( Hi ya Allen hope all is well,.. have a happy holiday from TX) . The DTQ will get you started, set up the cam selector for the 54 specs and then go V tune in flight mode. Good luck.
2012 FLTRX 124 S&S
124shark is offline
MasterTune (TTS) MAP Needed To Get Me Until Dyno Bdawson266 Map Section 16 04-26-2015 04:21 PM
PowerVision map needed for 54H cams, 103 68 EB Map Section 0 04-23-2015 06:31 AM
TTS MASTERTUNE w/ Software and TTS USB cable. Raiderse Classifieds Archive (3 months old+) 0 05-17-2012 04:08 AM
TTS MasterTune Map to stop Ping and high heat 2011 RGU? Raiderse ECM/Fuel Management systems 15 05-10-2012 01:52 PM
Get a great deal on TTS MasterTune BDMastiff Engine Related 35 05-28-2011 07:22 AM
