Tuner!!! - Road Glide Forums
post #1 of 13 (permalink) Old 01-03-2015, 09:52 AM Thread Starter
Q-Hog's Avatar
Tuner!!!
What's a good tuner for a "12 RG besides Thunder Max and uses the stock or stock size o2 sensors? Thx
Q-Hog is offline
post #2 of 13 (permalink) Old 01-03-2015, 10:25 AM
perrykw's Avatar
I will say that I AM NOT a tuner expert, but I just put a Power Vision on mine and have been happy thus far.
The weather has sucked here for a week so I haven't been able to ride much since the install, but I did take one short ride and was very happy. The PV plugs into the diagnostic port and can either be disconnected once the ECM is flashed or you can leave it hooked up to use it as gauges.
If you order from Fuel Moto, they can give you a map pre configured for your setup.
perrykw is offline
post #3 of 13 (permalink) Old 01-03-2015, 12:19 PM Thread Starter
Q-Hog's Avatar
Thx... I'll check it out.
Q-Hog is offline
post #4 of 13 (permalink) Old 01-03-2015, 12:27 PM
No expert here either, but my TTS Master Tune is working out well for me. Many good reviews on this and other forums. Purchased from Fullsac Performance along with their head pipe and CVO baffles. Also came with a free map for my set up. Runs great but, curious if by playing with it I could squeeze a little more out. Maybe not enough to tell. For now, "if it ain't broke don't fix it".
2012 FLTRX, vivid black
sometimer is offline
post #5 of 13 (permalink) Old 01-03-2015, 01:07 PM
dvanlue's Avatar
I bought the Power Vision and have been very happy with it. If I would have talked to Frank first, I would have purchased the Thunder Max just because he's my trusted answer man for all things engine related. It also has the ability to continually adjust the tune to the conditions, temp, altitude, etc. That said, he put a wicked tune on my PV with his 106 build on my bike. Also, the PV is a bit cheaper and even more so for multiple bikes.
2008 FLTR Candy Red Sunglo, S&S106, S&S push rods, Dragos 580 cams, Stage 2.5 heads, ported throttle body, Power Vision, Fuel Moto A/C, Aim lock up clutch, Dragos true duals, HogPro 21/18 Apollos, Ness hot legs, Native Customs cow bells.
2015 FLTRUSE Two tone blue.
dvanlue is offline
post #6 of 13 (permalink) Old 01-03-2015, 01:20 PM
laserman's Avatar
+2 on Power Vision Easy to use. Lot's of Maps available from S&S Cycle. Uses all your stock sensors but is upgradable if you go to a stage 4 to use a wide band sensor. Not saying by any means that would replace a good tune on a dyno. But you can get a decent tune without one. Currently using mine on a stage 4 107 heads and estimated 117HP and 124TQ. Engine runs around 210-230 depending on the day. I upgraded to the pro when I did stage 4.
laserman is offline
post #7 of 13 (permalink) Old 01-03-2015, 08:45 PM
Just ordered my TTS from Frank today (yeah, he called me back today because they were buried yesterday, how can you not give him 2 huge thumbs up for great service). Got the dual license so can do 2 bikes with one dongle. I've been researching for awhile and decided I didn't want to replace the ECM so the thundermax was out. A. ton of info on TTS, SEPRT and PV on the other forum. At then end of the day the TTS was the best option for me - made my mind up after talking to several dyno guys and reading till I was ready to puke. I don't think you can go wrong with the other units, the TTS was just the best fit for me. FWIW, the dyno guys I talked to really leaned toward the TTS or SEPRT (also mentioned the techno research direct link as a great unit as well) and were kind of luke warm towards the PV/Thundermax.
roadie13 is offline
post #8 of 13 (permalink) Old 01-03-2015, 09:11 PM
perrykw's Avatar
+1 on what roadie said. What pushed me over the edge on the PV was that my Indy knows how to tune with it and also spoke highly of fuel moto's stock maps. He did say he preferred the PCV, but that he also uses the PV. I guess a lot of it depends on what your local tuner uses. I have had nothing but outstanding service out of Fuelmoto, but I have also heard nothing but great things about Frank.
perrykw is offline
post #9 of 13 (permalink) Old 01-03-2015, 09:50 PM
Tuner RoadGlide
power vision
2013 Road Glide Custom Pearl Orange 7-13-2013
cvanmete is offline
post #10 of 13 (permalink) Old 01-03-2015, 10:04 PM
I have used the Vance and Hines tuners on my last two bike. The upside is priced, a little over $200.00. The down side is limited adjustability compared to a TMax or Power Vision.
If you are just doing pipes and a air cleaner, the Vance and Hines will work great. If you are thinking about cams, head work or things like that you may want to go with another tuner.
Hawkman
2017 Lagauna Orange FLTRX, 2013 Candy Orange Road Glide Custom (traded), 2010 Ultra Classic (traded), 2004 Classic (sold to little brother), 1999, Classic (traded), 1999 Road King (best handling so far), 1994 Softail Custom (traded), 1974 Superglide (I miss her still).
Hawkman is offline
SERT Tuner Obsolete, Not functioning, Buy new Tuner? hawk06Glide Dyno Results 22 04-04-2016 12:22 PM
SE tuner and Power Vision tuner question bigshaqa *General Road Glide Discussions/Pictures 8 01-11-2015 09:35 PM
tuner no tuner WTH????? motosig102 Intake and Exhaust 19 06-16-2013 02:36 PM
Best EFI Tuner? landshark Intake and Exhaust 16 03-21-2013 08:48 PM
HD Super Tuner vs HD SE Street Perf Tuner mhud3780 ECM/Fuel Management systems 1 02-18-2013 10:00 AM
