MM EFI to Carb conversion - Road Glide Forums
post #1 of 8 (permalink) Old 02-10-2015, 10:28 AM Thread Starter
I have done a buch of reading and think I may be interested in doing this. Only thing is I cant seem to find the Ignition Harness 32435-00 I found this
Anyone know if its the same harness?
Thanks
Jeff
Lunchbox
2001 HD FLTRI
Lunchboxx is offline
post #2 of 8 (permalink) Old 02-10-2015, 05:36 PM
sj01fltri's Avatar
I did my 01 RG and was very happy with it,not sure about the namz harness i used a stock harness,yoo may try contacting Namz to make sure.It looks very similar to the stock one.
sj01fltri is offline
post #3 of 8 (permalink) Old 02-11-2015, 09:33 AM Thread Starter
I sent Namz an email testerday and they said it was a direct replacement. What Carb did you go with. A friend of mine recommeded the SE 44mm carb
Lunchbox
2001 HD FLTRI
post #4 of 8 (permalink) Old 02-11-2015, 03:38 PM
sj01fltri's Avatar
42 mikuni,this motor was a 95 inch 10.25 comp,headwork and SE 211 cams,it was a blast to ride.
post #5 of 8 (permalink) Old 02-11-2015, 04:40 PM
h-donut's Avatar
subscribed
2010 FLTRX- r o a d g l i d e
h-donut is offline
post #6 of 8 (permalink) Old 02-11-2015, 05:04 PM Thread Starter
I have the Stock TC 88. He has an electraglide thats a couple years newer with th RC88 and he runs the SE 44 carb and says he loves it and he recommends the same carb to me. I dont know anything about carbs but I know his bike runs well and he can help me tune mine so I am thinking thats what I am gonna go with.
Lunchbox
2001 HD FLTRI
post #7 of 8 (permalink) Old 02-11-2015, 05:52 PM
if you have a stock 88 and dont plan any major mods a CV 40 will work and they can be picked up on Ebay for a decent deal if your patient .
As for the wiring harness if you have a good dealer he can look in the system and see if there are any of that part number anywhere in the country and tell you who has it then one phone call and you can get it sent to you , I did this with an obsolete part I needed my dealer found it I looked up the dealer that had it online called and bought it on the phone .
Eagle is offline
post #8 of 8 (permalink) Old 02-12-2015, 02:39 PM
sj01fltri's Avatar
I would suggest going with what ever carb you want,since you have a buddy that can tune it for you that's a plus,i went with the mikuni because of my engine mods plus i got a good deal on it.
Going from EFI to the good ol' carb... VikingRider Engine Related 6 06-11-2016 05:42 AM
Thundermax for MM efi replacement RGSRULE ECM/Fuel Management systems 15 03-05-2014 04:11 AM
MM EFI adjustment question Sobrbiker ECM/Fuel Management systems 8 10-24-2013 03:34 PM
1999 FLTRi efi to carb daxcobra Troubleshooting for Road Glides 5 12-29-2012 01:13 AM
MM EFI to Carb Conversion for a '01 RG v-rodder *General Road Glide Discussions/Pictures 10 05-19-2011 10:37 PM
