TTS tune question - ping in 5th and 6th - Road Glide Forums
post #1 of 7 (permalink) Old 02-18-2015, 11:06 AM Thread Starter
hi all,
my bike has a TTS and it was tuned well over a year ago. all is great but lately i have been noticing engine ping in 5th and 6th when i roll on it hard from 1/8-1/4 throttle. it is especially evident when i am going uphill under load. sounds like front cylinder.
does this sound like all they need to do is take a little timing out? do i need to go back to the original tuner to do this? or can any good tuner do that? does it need a full retune, or just a 10 minute software change?
this is my first time with TTS so that's why all the questions. thanks for the help
bike info: 103", 2012, 254E cams, fuel moto intake, fuel moto 2-1-2 head pipe, VH monster rounds
2012 FLTRX - stage 1.5 headwork, dragos 580 cams, 10.25 comp, FM stage 1 intake, dragula 2, TTS, 13" windvest, 14" evil apes, JRI 12" shocks, progressive monotubes, hertz and alpine, hawg wired amp, custom LED gauges, custom dynamics LED signals, lots o' powder coat
San Diego, CA
modot66 is offline
post #2 of 7 (permalink) Old 02-18-2015, 11:15 AM
pat123's Avatar
When you say lately do you mean in the last tank full of fuel. Maybe bad gas. Try a different supplier. What octane do you use. It's possible that you have a bit of carbon buildup. I have used sea foam in the fuel tank with great results.
pat123 is offline
post #3 of 7 (permalink) Old 02-18-2015, 11:21 AM
OneSlickGlide's Avatar
I have the same problem. It only seems to happen then the bike is hot and its when going from cruising to WOT like during passing, etc in and around the 2k-3k RPM range.
OneSlickGlide is offline
post #4 of 7 (permalink) Old 02-18-2015, 04:32 PM Thread Starter
thought the same thing but i have ran lots of tanks through it and no change. i only use 91 octane. i'm thinking it was always there i just finally noticed it one day.
San Diego, CA
modot66 is offline
post #5 of 7 (permalink) Old 02-18-2015, 04:34 PM Thread Starter
yep, that's where my ping is also. 2-3k in 5th or 6th then when i give 'er a good twist.
on a side note, what part of PA are you from? i grew up in carlisle, just south of harrisburg.
San Diego, CA
modot66 is offline
post #6 of 7 (permalink) Old 02-18-2015, 06:07 PM
I'm actually in Chambersburg. I'm about 20mins south of Carlisle down I81.
And that's exactly how mine is also. Running a PC5 with an auto tune and my auto tune will not adjust it. I had a $50 run for A/F done last summer at a local bike night and it was running lean in that RPM range.
I too have also read about it being timing. I might have it redynoed this summer. I'll just by some Dragos 580 cams before I do that.
post #7 of 7 (permalink) Old 02-20-2015, 07:24 AM
Pull a couple degrees of timing out at the RPM range between 50-70 MAP. best thing to do is do a data run with TTS hooked up and see exactly where ping occurs and then reduce timing.
pittz5 is offline
'18 114-in Stage=4 with TTS cams and TTS tuner Sharkbreath Dyno Results 12 12-16-2017 10:02 AM
TTS MASTERTUNE w/ Software and TTS USB cable. Raiderse Classifieds Archive (3 months old+) 0 05-17-2012 04:08 AM
TTS MasterTune Map to stop Ping and high heat 2011 RGU? Raiderse ECM/Fuel Management systems 15 05-10-2012 01:52 PM
ping... Ping... PING philmartin *General Road Glide Discussions/Pictures 20 07-25-2011 09:10 PM
Needing help with TTS V-Tune LMS ECM/Fuel Management systems 20 05-04-2011 04:38 PM
