Wide Band O2 Placement???? - Road Glide Forums
post #1 of 5 (permalink) Old 02-22-2015, 09:56 PM Thread Starter
I purchased a Power Vision With Auto tune Pro from FM I need to get Bungs welded into pipes but I am not sure how far from flange to put them. Is there a standard or ?
Didn't see anything in the instructions.
Thanks for the help!!!
mustangoutcast is offline
post #2 of 5 (permalink) Old 02-22-2015, 10:05 PM
perrykw's Avatar
My headers had both sizes preinstalled. The wide band holes were pretty far up on the pipe but I don't have exact measurements. I would call FM. They have always been very helpful when I called.
perrykw is offline
post #3 of 5 (permalink) Old 02-23-2015, 03:13 AM
Q-Hog's Avatar
You can buy a set from eBay, Amazon or summit racing. Just make sure you weld them in the correct location for the sensors to be easily installed and it doesn't interfere with installment of the headers and heat shields. I did a set on mine. Good luck.
Q-Hog is offline
post #4 of 5 (permalink) Old 02-23-2015, 09:01 AM
The closer to the exhaust port the better. On my 08 the 18mm 02 bungs are about 6 to 8 inches away from the exhaust port in the front and around 8 to 10 inches away from the exhaust port on the rear.
My exhaust is a little different then your is because I run a true dual that has the rear head pipe exiting on the left.
The main thing to look for is to put the 02 sensors in a location that you can service them later on without removing the exhaust, both of my 02 sensors can be installed/removed without removing the exhaust.
post #5 of 5 (permalink) Old 02-23-2015, 05:12 PM
when I had my bike dyno tuned, Ed drilled new holes 4-6 inches from the heads for the wide bands. Couldn't leave them there full time while riding though. I think form will have to be considered over purely function.
2012 Road Glide Ultra
79HP 103 TQ, tuned by Ed at The Dyno Difference.
tsigwing is offline
How wide is too wide? Slammed Controls & Handlebars 3 11-01-2014 02:22 AM
V & H Power Dual's 12mm O2 Bung Placement tanglefoot Intake and Exhaust 3 05-16-2014 10:59 AM
Anyone running the wide band sensors with the Power Vision? Fire-Medic ECM/Fuel Management systems 18 03-29-2014 07:52 PM
What's the difference between Wide Band and Narrow Band O2 sensors? Timinfla2 Intake and Exhaust 4 04-26-2011 01:23 PM
Wide band O2 sensors Glideliner ECM/Fuel Management systems 2 09-24-2010 04:13 PM
