Screamin Eagle Pro Tuner reflash question - Road Glide Forums
post #1 of 7 (permalink) Old 02-28-2015, 07:37 PM Thread Starter
RootBeerFXS's Avatar
Ok, bought my 13 RG last October from a local HD dealer. Bike has D&D Exhaust, Heavy Bretather, 255 cams and heavy clutch spring confirmed from installing dealer. The previous owner did not hand over the tuner when he traded it in. I see used ones on eBay for sale with a footnote saying it has to be reflashed to use on a different ECM. Anyone been this route?
I am only getting 26 mpg and need to try to remedy this before the Sturgis trip. Thanks.
1985 ExciteBike Champion
RootBeerFXS is offline
post #2 of 7 (permalink) Old 02-28-2015, 10:08 PM
Think that once they are tied to a bike, its a lifetime deal. The po screwed you. If you are close to Dallas though, Ed at the dyno difference can take care of you.
2012 Road Glide Ultra
79HP 103 TQ, tuned by Ed at The Dyno Difference.
tsigwing is offline
post #3 of 7 (permalink) Old 03-01-2015, 05:42 AM
Ohiobellboy's Avatar
Have the dealer contact the PO about getting it back. Those things are around $400. GMR is another reputable builder/tuner in the Dallas area just to give you another option.
A.K.A OBB
Ohiobellboy is offline
post #4 of 7 (permalink) Old 03-01-2015, 09:01 AM Thread Starter
Dealer is "looking into it". Dyno Diff is right around the corner from me. GMR is not too far. Thanks.
post #5 of 7 (permalink) Old 03-01-2015, 10:39 AM
If you need to buy a tuner you don't have to get the HD SE tuners there are aftermarket tuners that will work for around the same money.
post #6 of 7 (permalink) Old 03-01-2015, 02:07 PM
skratch's Avatar
being close to both gmr and dyno difference, if you plan on using one of them, see what they recommend.
skratch is online now
post #7 of 7 (permalink) Old 03-20-2015, 07:00 PM
Sounds like whoever did the original tuning was not that experienced with it. Your combo should give you mpg readings in the mid-30s or better. Hopefully, you can get the module from the dealer or the original owner, as he shouldn't need it after selling the bike.
BW TC-44 cams; Fueling race lifters; SE Pro Tuner, ported/polished heads, 10.5 pistons, HV oil pump/camplate; RSD AC; Fullsac/Rinehart 4"
MadCVORG is offline
Screamin Eagle Pro Street Tuner bykw2 Parts for Sale 14 01-31-2018 09:17 AM
install question screamin eagle pro breather THEMASTERDESTROYER Intake and Exhaust 0 04-21-2015 03:55 PM
Screamin eagle pro tuner map for 120 r into 2015 roadglide c3sar3 ECM/Fuel Management systems 1 03-29-2015 01:49 AM
Screamin’ Eagle® Pro Super Tuner Steve ECM/Fuel Management systems 5 08-03-2011 08:01 PM
Is it ok to run Ness Stage II sucker without tuner or reflash DED HD Intake and Exhaust 17 08-04-2010 02:36 PM
