question - Road Glide Forums
post #1 of 12 (permalink) Old 03-12-2015, 09:18 AM Thread Starter
question
Hi guys, I have a 09 with slip ons and other than that my only future mods to the motor would be a A/C. I know nothing ZERO about these fuel management systems. There are so many different ones out there it has confused me even more. Due to money constraints, I will be purchasing a "plug and play" type, paying for dyne time now is out of the equation. I would like to hear what everyones thoughts are on these and what seems to work the best and is easy to install. My main focus is reliability and running properly.
Thanks
phillyfan1 is offline
post #2 of 12 (permalink) Old 03-12-2015, 09:37 AM
sfcusaret2004's Avatar
I'm in the same boat and after much searching and researching I'm torn between two solutions to the lean issue. I'm considering the Nightrider performance Vied/Xied (http://sales.nightrider.com/), and the Dobeck engineering EJK (http://www.dobeckperformance.com/dobeck-products.asp) Both of these systems plug directly in between the o2 sensors and the ECU. This fools the stock ecu into providing a richer mixture to the injectors which corrects the lean condition produced when a freer flowing A/C and exhaust are added to the bike. I have heard some say that the stock ECU can correct for the added air/fuel changes but prefer to have control over that myself. I'm leaning towards the dobeck controller myself as there is greater flexibility/adjustability in this system and it has direct feedback via the led vs the xied/vied which only have a setscrew to enrichen/lean out the mixture and you would have to rely on the seat of your pants or a dyno to verify the results. Since I also have a 7 year ESP I want to be able to remove the system if necessary for warranty work without the hassle from the dealer. Hope this helps you decide, but I'm sure there will be a ton of response here either way to either system.
sfcusaret2004 is offline
post #3 of 12 (permalink) Old 03-12-2015, 06:53 PM Thread Starter
Thanks for your reply? Something you are doing soon? Would like to hear how either one works for you
post #4 of 12 (permalink) Old 03-12-2015, 08:18 PM
perrykw's Avatar
I have the Power Vision and am running a tune from Fuel Moto.
perrykw is offline
post #5 of 12 (permalink) Old 03-12-2015, 08:39 PM
cecild's Avatar
I had great results from the cobra fi2000 unit. Easy to install and setup. Used it until I did mods that required a programmer.
cecild is offline
post #6 of 12 (permalink) Old 03-12-2015, 08:43 PM Thread Starter
I have looked at that one. Any issues with it at all? Reliability is a must for me. That and easy to install.
post #7 of 12 (permalink) Old 03-12-2015, 09:00 PM
cecild's Avatar
I ran it for 2 years and had no issues(and I ride approx. 20,000/yr). Only has one adjustment for mixture. Once you find your sweet spot your ready. I had noticeable performance gains and great fuel mileage. I have now gone to the PowerVision after doing some other upgrades.
There are others on the market since I had gotten it and can't speak to there record.
cecild is offline
post #8 of 12 (permalink) Old 03-12-2015, 09:25 PM Thread Starter
Thanks man. Very appreciated
post #9 of 12 (permalink) Old 03-13-2015, 10:34 AM
The Power Vision is a much better tuner then the Cobra Fi2000 is.
post #10 of 12 (permalink) Old 03-13-2015, 01:52 PM Thread Starter
Did you install this yourself? If so, how would you rate the process? Dyno after?
Speaker Question (not a fitment question) FLTRXS18 Audio 9 12-31-2014 01:58 PM
Amp fit question -Newbie Question Slider57 Audio 13 05-17-2013 11:47 AM
