Thundermax Yes or NO! - Road Glide Forums
post #1 of 19 (permalink) Old 03-19-2015, 09:30 AM Thread Starter
have a 2009 Ultra classic and had a PC V on it with dyno and all Was good. Bike quit running and had to take PC V off. It was dead. Less than3 years old. I have seen a lot of talk about Thundermax tuners but am wondering if they are as good as they say? Put them on and put a close tune to it and then ride and it auto tunes your bike. 1st,, is it that simple and does it do a good job? I don't wamt to spend that much money and not do what I want. 2nd ... if they are that good, where is best Place to buy one at best price? Thanks for listening and for any help.
forace2009 is offline
post #2 of 19 (permalink) Old 03-19-2015, 09:40 AM
tsmartt's Avatar
I had a Thundermax with autotune on my 01 RK with a major engine build and it worked great. Thundermax tuner is the first thing I did on my 13 RGC. It works great. I did the exhaust and breather on the first round. Loaded a map and let autotune do its work. Then I added cams. Loaded another map and let autotune work. It is easy to install and manage.
You will get a lot of comments about not getting the most out of your engine unless you get the bike dyno tuned. That may be true, but the reason I got the TMax with autotune was so that I could make changes and not have to worry about a dyno tune every time. And it works.
I bought mine from Frank Drago at Dragos Bike Works. He is a forum sponsor and gives members a discount. Give him a call. You won't be disappointed. Good luck. www.dragosbikeworks.com.
Quattro / 16 RGS / Dragula2 2:1 / Drago 565 / ThunderMax Tuner / Fuel Moto Breather / Klock Werks Flare / Custom Dynamics LEDs
Orange Crush / 13 RGC / Dragula 2:1 / TMan 555TQ / ThunderMax Tuner / Zipper's Max-flow Breather / Klock Werks Flare / Custom Dynamics LEDs
tsmartt is offline
post #3 of 19 (permalink) Old 03-19-2015, 09:43 AM
pat123's Avatar
Hell NO. Everybody has there opinion as do I. I wasted 8 bills on a tmax. Nothing beats a DYNO tuned bike. Talk to a LOCAL tuner and ask his advice. do it once and do it right.
I went through a few tuners PV,tmax and TTS to get the results I wanted. I found a local tuner and asked his advice and now my bike flat out runs awesome.
Tmax doesn't use any knock control like the stock pcm. no safe guards.
pat123 is offline
post #4 of 19 (permalink) Old 03-19-2015, 10:18 AM
First of all any auto tuner will only AUTO TUNE THE AFR. There is no auto tuner on the market that auto tunes the timing.
If you get a T-max you have to load a base map that is close to your build and then ride the bike and let the auto tune tune the AFR then if there is any pinging you have to make the timing adjustments which is easy to do.
I run a T-max and I made all my timing adjustments and the bike runs great.
The T-max is a good tuner to have if you plan on doing engine mods later on or want to change from one mod to another mod because you don't need to have the bike dyno tuned.
Most people that don't like the T-max tuner don't take the time to learn how to or take the time to make the adjustments in timing or they take their bike to a dyno tech that is not familiar with the T-max tuner and they end up with less then satisfactory results.
DO NOT expect to just load a base map and not make any timing adjustments (unless you get lucky) , you may need to make multiple timing adjustments to get everything right.
Taking your bike to have a dyno tune can be expensive and in many cases result in disappointing results because the dyno tech doesn't know what he is doing.
post #5 of 19 (permalink) Old 03-19-2015, 10:23 AM
I agree with Ironmark, and as far as the best price, I agree withTsmartt, BTW I'm on my 2nd bike with the TMax and am very happy with it.
post #6 of 19 (permalink) Old 03-19-2015, 10:54 AM Thread Starter
Thanks for replies so far
I appreciate the response so far. will contact Frank at Dragos. If anybody else has any other suggestions I am still open.
Thanks
post #7 of 19 (permalink) Old 03-19-2015, 10:54 AM
eme56's Avatar
I also agree with Ironmark. Nothing is perfect out of the box, but if you spend a little time, the Thundermax will do its job. I purchased mine from Jamie at FuelMoto. He had the model I needed in stock at the time I was looking. If you buy it from either Jamie or Frank, they will set you up with a base map that is very close. Would I buy one again for a new bike? Hell yes.
2005 FLTRI Black Cherry, 95" Big Bore, Thundermax w/Auto Tune, V&H Dresser Duals w/Klock Werks SS, Andrews 26 Cams, SE Stage 1 intake, SE OD/6 Speed, Wards FCS cooling fans, Krome Werks Stretch Heritage +2 bars, Progressive Monotubes, 444's, & Touring Link, Michelin Commander II's, 14.5" Madstad, Lowers with Classic Motorcycle Vents, detachable King Tour Pack, Daymakers
eme56 is offline
post #8 of 19 (permalink) Old 03-19-2015, 10:55 AM
pat123's Avatar
My dyno tune with the TTS was 817.00 out the door. That included the TTS and tune. The tmax was 800.00 The tuner pulled a extra 20hp and 23tq over the tmax.
I agree about tuning the timing on the tmax so when you think about it the tmax costs more than the actual tts and a tune. Add another 400.00 to the top of the tmax= 1200.00.
pat123 is offline
post #9 of 19 (permalink) Old 03-19-2015, 12:42 PM
lonerider's Avatar
I have to admit the Thundermax is the only tuner I have ever had, never put one on my
Wide Glide yet. But with that said I don't have any reason to want anything else.I put it on
the same time I put the MGS exhaust on and haven't looked back. Have had 0 problems with it.
lonerider is offline
post #10 of 19 (permalink) Old 03-19-2015, 02:51 PM
Ran two thundermxx for nine years!! Zero problems first one was a zippers 120 with DD boarzilla second was fuel moto 107 with DD fat cat 777 woods cams...both bikes were flawless and only dyno tuned for purposes of seeing what it would make.. Drove the bikes from Sturgis to Miami beach and everywhere in between...I can not speak for others but it just works for me!! highly recommend !! my new build is from Frank Drago 107 diablo 2.5 kit with his pipe and thundermaxx waiting on parts now!! Frank gives thundrmaxx a full thumbs up!
tjvazquez11 is offline
Mount Power Vision? Yes or No? Ernster500 ECM/Fuel Management systems 14 04-02-2018 07:15 PM
Detachable Tour Pak Yes or No? tomerza Paint & Bodywork Section 24 02-12-2016 01:48 PM
Sancho's wings YES/NO??? scuba1954 Windshields 103 11-08-2012 05:02 PM
Saddlebag Guards-yes or no? Xaran *General Road Glide Discussions/Pictures 114 09-02-2012 10:00 AM
Avon grips suck? Yes no maybe? Blackrg Controls & Handlebars 12 08-30-2011 08:09 AM
