rpms didn't go down after letting off throttle. - Road Glide Forums
post #1 of 7 (permalink) Old 03-22-2015, 09:27 AM Thread Starter
Thismorning i walked out and cranked my bike while standing beside it. I twisted the throttle and raced it upand let go. It didn,t spring back like itshould and the engine reved high. I twisted it back and it came down toidle. I shut offthe inition and did it again the throttletwisted back slowly. Didn't springback. It is a 13 RG ULTRA. Isit the throttle sensor.
Straitline is offline
post #2 of 7 (permalink) Old 03-22-2015, 09:42 AM
Claudiov's Avatar
Sounds like your throttle grip could possibly be getting stuck. I've had that issue, I just put some WD-40 and problem solved.
Colt .45...Absolutely NEVER leave home without it.
Claudiov is offline
post #3 of 7 (permalink) Old 03-22-2015, 09:45 AM Thread Starter
Ill give that a try. Thanks
post #4 of 7 (permalink) Old 03-22-2015, 09:50 AM
Ohiobellboy's Avatar
I had a little burr on my handlebars on my '11 causing it to stick. Pulled the grip, hit it with some fine sandpaper and problem solved. Another thing could be the grip is pushed in against the control housing causing a slight bind.
A.K.A OBB
Ohiobellboy is offline
post #5 of 7 (permalink) Old 03-22-2015, 09:56 AM
WD 40 isn't going to help. Did you do any work to the switch housing or throttle grips lately.
It sound like the throttle grip is in to tight on the TGS (Twist Grip Sensor) loosen the switch assembly a little and slide the throttle grip out about a 1/16 to a 1/8 of a inch then tighten everything down.
post #6 of 7 (permalink) Old 03-22-2015, 10:13 AM
I had a similar problem recently, it ended up being the intake gasket on the TB.
post #7 of 7 (permalink) Old 03-22-2015, 10:34 AM Thread Starter
I took the the brake and the twist grip off and checked the throttle position indicator for spring back return. There was no problem there. So I put it back together and it working just fine now. Thanks for the info brothers.
Some go Black Some go Chrome I go my way BACA POPEYE *General Road Glide Discussions/Pictures 66 06-21-2019 09:58 AM
Very loud clank when shifting or getting on throttle or letting off throttle Callahan69 Engine Related 28 11-14-2016 01:09 PM
Thinking of letting Candy go!! g1shadow *General Road Glide Discussions/Pictures 21 01-15-2016 08:32 PM
Spring cleaning so I'm letting some things go Othello7213 Parts for Sale 27 05-02-2013 08:46 PM
2005 Roadglide starting to sputter between 2500-3000 rpms Hawkydog Troubleshooting for Road Glides 5 09-14-2012 09:51 AM
