TTS "no matching tables" - Road Glide Forums
post #1 of 3 (permalink) Old 04-09-2015, 12:55 PM Thread Starter
i was trying to load a TTS base map and got a message saying my file was obsolete and would need to copy it into another tune file to save and run. however, when i copied the cells into the new file i got messages saying there were no macthing tables for the following: main lambda, PE lambda, closed throttle spark front and rear.
anyone ever dealt with this? i am familiar with lambda and am guessing the file i have must have been programmed with AFR instead of lambda?
i'm lost at this point...
2012 FLTRX - stage 1.5 headwork, dragos 580 cams, 10.25 comp, FM stage 1 intake, dragula 2, TTS, 13" windvest, 14" evil apes, JRI 12" shocks, progressive monotubes, hertz and alpine, hawg wired amp, custom LED gauges, custom dynamics LED signals, lots o' powder coat
San Diego, CA
modot66 is offline
post #2 of 3 (permalink) Old 04-09-2015, 01:43 PM
griswold's Avatar
I had a similar issue. The MAP (kPu) on the Main Lambda had different intervals than the obsolete map. I believe it was 20 25 30 (old) vs 15 20 30 new or something similar. It still loaded the map however and ran fine.
2010 FLTRX, 2003 FXDX, 1983 XLH1000, 1975 FLH
griswold is offline
post #3 of 3 (permalink) Old 04-09-2015, 03:46 PM Thread Starter
sweet man thanks. i have a call into TTS to ask them about it and will post up answers when i get them back.
San Diego, CA
modot66 is offline
'18 114-in Stage=4 with TTS cams and TTS tuner Sharkbreath Dyno Results 12 12-16-2017 10:02 AM
TTS experts - merging fuel tables and VE tables from 2 tunes modot66 ECM/Fuel Management systems 6 09-12-2015 03:32 PM
Power Vision and Open Loop Tables triumphwes ECM/Fuel Management systems 2 04-04-2013 02:52 PM
TTS MASTERTUNE w/ Software and TTS USB cable. Raiderse Classifieds Archive (3 months old+) 0 05-17-2012 04:08 AM
Air lift tables swampercj General Off-Topic Discussions 7 02-10-2011 12:54 PM
