Do i need a ....? - Road Glide Forums
post #1 of 8 (permalink) Old 08-25-2010, 08:31 PM Thread Starter
Question Do i need a ....?
New to the HD world so I need some info. I just bought an 06 RG with a K&N filter and a complete D & D Fat Cat 4" 2-1 exhaust (headers with bungs). My bike is an 88 ci EFI but my understanding is that it did not have O2 sensors prior to the 96 ci in 07. My question is, do I need a fuel management system/ tuner/ PCV or is my bike okay with a "map". It idles great, throttle is responsive but occassional "pop" on deceleration.
Thanks in advance, love this forum.
newtome is offline
post #2 of 8 (permalink) Old 08-25-2010, 09:32 PM
slowglide2989's Avatar
Initially I would say yes, but who knows what it has already. Most people think just because they have a decel pop they are lean. Its not always true. It is fresh air mixing with unburned fuel in the exhaust. But, long story short, your bike being pre-2007, i would get a tuner for it. The newer efi's 2007 and later are fine with an intake and exhaust.
Im sure this will turn up much debate, but from my experience and conversations with knowledgable tuners the efi was changed by adding o2 sensors in the later year efi bikes this keeps the afr the same while in closed loop it keeps the AR the same as it was completely stock.
Hope this helps
slowglide2989 is offline
post #3 of 8 (permalink) Old 08-26-2010, 03:11 AM
cem1133's Avatar
My 03 had that same pop during decel. Never seemed to hurt it and I never had any problems so I left her alone.
07 roady with 10"yaffee Bars. C&C seat. 12" winvest. Custom bag top paint. 1" lowered in rear.
cem1133 is offline
post #4 of 8 (permalink) Old 08-26-2010, 09:03 AM
DED HD's Avatar
Are you sure it doesnt have a Race Tuner Already?
I had an 06 Street Glide, and when i switched to Rineharts True Duals, I bought the SE Race Tuner Kit, which i believe is only used to re-map. I dont think it stays on the bike. Anybody else know if that was true of the old Race Tuners.
I still have the little black module that says EFI Race Tuner Kit and has ports on both sides. I sold the bike, but i think if someone took the Rineharts off, They would need this module to go back to the stock configuration.
'10 Red Custom:
DED HD is offline
post #5 of 8 (permalink) Old 08-26-2010, 10:59 AM Thread Starter
Thanks for info GR8FLH. I will see if there is anything by the ECM; how big is the module?
newtome is offline
post #6 of 8 (permalink) Old 08-26-2010, 02:28 PM
DED HD's Avatar
The module I have is as big as a small cell phone. Maybe like 4"x2"x1". the model number i think is 32114-01A. i think its the same size as the current Race Tuner.
This part is from 2006.
'10 Red Custom:
DED HD is offline
post #7 of 8 (permalink) Old 08-27-2010, 07:06 PM Thread Starter
GR8FLH, thanks for the info. I will pull my righ cover and check.
newtome is offline
post #8 of 8 (permalink) Old 09-02-2010, 07:49 PM Thread Starter
Took a look while washing my bike the other day, no TFI/ PC etc on bike it was mapped when the exhaust was changed. Thinking of a TFI from Dobeck next spring or a PC III.
newtome is offline
What do you do to make a living ? slaterman5 General Off-Topic Discussions 1474 07-21-2019 04:10 PM
OK, do I need to do something with the back of my tour pack? ChromeYellow67 *General Road Glide Discussions/Pictures 90 12-05-2012 06:35 AM
Do I need a do-over on primary? xshovelfreak Troubleshooting for Road Glides 2 08-28-2012 08:55 PM
What do u do when you drive up in back of a group of BANDITOS? BillyBob *General Road Glide Discussions/Pictures 63 02-13-2011 12:23 PM
After you install J&M or other speakers, what do you do with the factory speakers? Black09inOK Do-IT-Yourself 6 10-01-2010 01:53 AM
