Map for 2015 Road Glide - Road Glide Forums
post #1 of 4 (permalink) Old 05-20-2015, 07:20 PM Thread Starter
Just purchased 2015 Road Glide Special (FLTRXS). Installed Mean Mother's SuperTrapp slip-ons, Perfomance Machine MAXHP air cleaner, Cobra head pipes, and finally got my HD SE Pro Super Tuner. Anyone know off hand what is the closest map that I can use? Thank you.
blajj is offline
post #2 of 4 (permalink) Old 05-20-2015, 08:18 PM
Get a dyno & be done with it. Just my 2 cents. Good luck whichever way you go.
2011 FLTRX 103 Sedona Orange
Hillglide is offline
post #3 of 4 (permalink) Old 05-21-2015, 04:49 AM Thread Starter
U-R right, and that's what I'll do! Thanks for response.
blajj is offline
post #4 of 4 (permalink) Old 06-23-2015, 10:43 PM
If you have all the cables you can select a map on the program from harley parts that are close to what you put on the bike then use the data (or tuning mode, I can't remember what its called) and tune it pretty darn well your self. If you want every last bit of power go to a dyno if you have someone competent enough to operate it near you. You can get it real close tuning your self if you have time though.
CashMoney is offline
Need map and have map to share Hack73 Map Section 0 10-03-2016 04:42 AM
2015 Road Glide Map - Powervision billygoat94 Map Section 3 07-23-2015 09:13 PM
map needed for 13 cvo road glide rickpay1 Map Section 0 05-03-2015 05:59 PM
Screamin eagle pro tuner map for 120 r into 2015 roadglide c3sar3 ECM/Fuel Management systems 1 03-29-2015 01:49 AM
2015 Road Glide on 2009 Road Glide?? RGLove12 General Off-Topic Discussions 3 01-13-2015 09:29 PM
