Power Vision works intermittently - Road Glide Forums
post #1 of 8 (permalink) Old 05-27-2015, 08:24 AM Thread Starter
elbohead's Avatar
I like to keep my PV mounted on the bike to use the gauges while riding. The engine temp and gear indicator gauges specifically. I've been having issues lately where they go blank after a short period of time. By this I mean the screen still reads "Engine Temp" and "Gear" but there are no longer numeric values. The only way to reset is to pull the connection, and plug it back in. Or shut the bike off and start over.
Occasionally, all will be fine for 30 minutes or more, but most times this happens after only a minute or two.
Anyone else run into this problem?
Thanks!
2012 FLTRX, BBP, 13" MadStad, Fuel Moto Pro Billet AC and 4" Dyno Tuned Jackpots, catless header, DinoJet Power Vision, Horizon Helibars, Iron Aces mount, HD Aileron grips, Ward's cooling fans, Mustang Wide Tripper solo, CD Plasma Rods and LED turns...
elbohead is offline
post #2 of 8 (permalink) Old 05-27-2015, 08:32 AM
tdkkart's Avatar
Where do you have the cable running up to the bars. Lock-ups cause by electrical interference are quite common if the cable is just tucked up over the motor under the tank. Too close to the plug wires.
I've had mine running on the bars for thousands of miles. Had problems initially when the cable was temporarily installed. Once I pulled the tank and ran the cable through the wiring tray under the tank I've never had another problem.
tdkkart is offline
post #3 of 8 (permalink) Old 05-27-2015, 08:48 AM
this was exactly my problem when I first installed mine and had the same symptoms that you are having!!!
2013 RGU, black of course....
y2kflhr is offline
post #4 of 8 (permalink) Old 05-27-2015, 09:05 AM Thread Starter
elbohead's Avatar
Thanks for the help. It is appreciated!
Here is a pic of the PV wire coming out from the side cover and running on top of the tank. Should I pull the tank and run it underneath?
elbohead is offline
post #5 of 8 (permalink) Old 05-27-2015, 09:22 AM
no that is the way it should be run, is it possible the cable is kinked?
y2kflhr is offline
post #6 of 8 (permalink) Old 05-27-2015, 09:33 AM Thread Starter
elbohead's Avatar
Maybe. I'll check it from end to end.
elbohead is offline
post #7 of 8 (permalink) Old 05-27-2015, 09:44 AM
PGR
PGR's Avatar
Here's who you need to ask
http://www.dynojet.com/powervision/p...ontact-us.aspx
Ron..........................
PGR is offline
post #8 of 8 (permalink) Old 05-27-2015, 10:00 AM
quikcarl61's Avatar
That's the way I ran mine and have had zero problems, also using the Iron Aces mount
quikcarl61 is offline
$799 Power Package Street Outlaw mufflers, Power Vision, FM Stage 1 AC fuelmoto Fuel Moto 7 06-16-2018 02:37 PM
LED's, power commander, power vision, and other items for touring models. Gasitman Parts for Sale 5 08-23-2014 12:29 AM
Engine skips on roll-on after deceleration intermittently. KiloGolf4 Engine Related 4 08-19-2014 09:53 PM
Cruise control working intermittently? motodrummer Controls & Handlebars 4 03-23-2012 07:31 AM
Power Command Power Vision problem help! BigDave55 ECM/Fuel Management systems 11 08-06-2011 07:21 AM
