Stage 1 mod help - Road Glide Forums
post #1 of 10 (permalink) Old 05-28-2015, 02:48 PM Thread Starter
MASQUEDMANN's Avatar
Stage 1 mod help
Installed dragos hpipe and 4inch dragula mufflers along with an arlen ness big sucker started the bike up yesterday and the engine light came on. Is this due to the new mods?
I have the power vision from fuel moto with a map for the stage one mods will the power vision correct the engine light issue or give me a code?
Tia
Masque
MASQUEDMANN is offline
post #2 of 10 (permalink) Old 05-28-2015, 03:01 PM
I believe you can look the codes up with the power vision. I think you can reset them as well. I could be wrong tho.
How do you like the sound? I am think of going with his mufflers with my rush h pipe?
[B]PV-Big Sucker-Rush Racing H-pipe-Big Louie's-Drago's 565 cams
Nightrain04 is offline
post #3 of 10 (permalink) Old 05-28-2015, 04:19 PM Thread Starter
Only listened to it in the garage sounded good and not abnoxious. Will get a better review this weekend when I open the bike up on the highway.
post #4 of 10 (permalink) Old 05-28-2015, 04:20 PM Thread Starter
Hoping the engine light is just due to the stage 1 mod. Hooking up the power vision tomorrow
post #5 of 10 (permalink) Old 05-28-2015, 04:23 PM
One thing to check is to make sure the oxygen sensors are in the correct. The one with the black plug goes to the rear cylinder.
post #6 of 10 (permalink) Old 05-28-2015, 06:07 PM Thread Starter
Thanks Nightrain04 I made sure of that during the install but I'm definitely going to double check
post #7 of 10 (permalink) Old 06-12-2015, 07:59 AM
glacieredlightning's Avatar
Were you able to clear the codes? what was the issue? How does the bike perform and sound on the highway now??
GD
It is all stock ... yes it is!
glacieredlightning is offline
post #8 of 10 (permalink) Old 06-12-2015, 09:11 AM
The engine light means you have a DTC code. You do not need to hook up the power vision to check and clear DTC codes, there is a sticky on how to check and clear the DTCs in the troubleshooting section.
You may have to change the base map on the powervision because of the mods.
post #9 of 10 (permalink) Old 06-12-2015, 01:38 PM Thread Starter
glacieredlighting haven't had a chance to check it out. Will be back at it this coming week
post #10 of 10 (permalink) Old 06-12-2015, 01:38 PM Thread Starter
Thanks ironmark
Fairing Lowers CVO Speaker Box Mod.... Help 2stangs8689 Audio 12 11-28-2014 05:01 PM
Help needed in selecting audio mod Tim Powell Audio 0 09-12-2014 05:02 AM
Fuel Moto Stage 1 Kit + Stock AC Mod NORSEMAN Intake and Exhaust 5 02-28-2013 07:50 AM
mod leads to mod after mod, i need to be locked up (-: mroach *General Road Glide Discussions/Pictures 14 07-29-2012 09:04 PM
Stage 1 to Stage 2 progression Indy Road Dog Engine Related 2 10-21-2010 06:18 AM
