Pc 5 - Road Glide Forums
post #1 of 11 (permalink) Old 09-06-2010, 06:45 PM Thread Starter
hodgeaaco's Avatar
Pc 5
I gotta say, I am more impressed with the PC 5 everyday. I was a little indifferent at first; I bought it with a pre-loaded map because no one had a map for my exact set-up. It ran well but had some decel pop and the occasional pop between shifts. I was a little leery of trying to make adjustments myself, but after talking with FuelMoto, decided to venture into the world of self tuning. I am not sure what I was afraid of, but the PC5 is really simple to adjust. I have adjusted a few of the throttle position #'s at different RPM's and viola!! no more popping and it sounds pretty mean on hard decel...almost NASCARish! Does this qualify me to be a "tuner"?
2010 FLTRX - "Black Plague"
hodgeaaco is offline
post #2 of 11 (permalink) Old 09-07-2010, 04:25 PM
Yes it does! lol
RoadGlide0611 is offline
post #3 of 11 (permalink) Old 09-07-2010, 05:03 PM
tuneAfish's Avatar
you might want to look into a set of theses> http://www.amazon.com/Dynojet-Wide-B.../dp/B0030IHGGA
If you ride in elevation changing environments, I talked to a good tuner guy and he is packaging the 5 with these and says once your dialed in you have a 20% auto adjustment for AFM up or down.
[Disclaimer] Sorry if I'm blunt, I fell off my mini bike when I was little and lost the ability to give a sh*t.
tuneAfish is offline
post #4 of 11 (permalink) Old 09-08-2010, 12:25 PM Thread Starter
hodgeaaco's Avatar
What is the difference between that and the autotune, other than price?
post #5 of 11 (permalink) Old 09-08-2010, 02:51 PM
tuneAfish's Avatar
It is the auto tune for PC-5 > https://cart.jetkit.com/p-1799-autot...-o2-bungs.aspx
post #6 of 11 (permalink) Old 09-11-2010, 02:53 PM
How hard is this to adjust? I'm thinking of buying a used one but if I need help with adjustment, than I should buy a new one.
post #7 of 11 (permalink) Old 09-13-2010, 12:01 PM
What head pipe/exhaust? I have the stock head pipe and the
auto-tune will not fit without changing the bungs
ROADEAGLE is offline
post #8 of 11 (permalink) Old 09-13-2010, 12:47 PM
tuneAfish's Avatar
The website has some baseline downloads, then a dyno tune would be best to get it in the sweet spot. then the Auto Tune (if installed) will adjust AF up or down 20% for changing conditions like altitude.
post #9 of 11 (permalink) Old 09-13-2010, 12:49 PM
tuneAfish's Avatar
I like the V&H dresser duals. [biased opinion]
post #10 of 11 (permalink) Old 09-14-2010, 08:46 PM
Pc v
Read a article in American Iron. Altitude and enviroment are regulated at intake a.k.a mass air flow sensor. Currently running 09 RG. PC-5 bungs capped. Bub header w/ Flying Hogs, Jet scream intake.72hp 84T.
flyingpig is offline
When is Mastertune better than PC-V or vice versa? Gadgetech ECM/Fuel Management systems 45 07-01-2011 12:23 PM
Map for PC III USB for 06 RG kimmer127 ECM/Fuel Management systems 2 10-15-2010 03:18 PM
Rev Extender PC 111 sportyguy69 ECM/Fuel Management systems 0 08-28-2010 09:18 PM
PC Racing Flo Washable Oil Filter DreamRider Aftermarket Accessories 13 07-12-2010 05:20 PM
PC lower legs sharkey1250 Aftermarket Accessories 1 02-03-2010 08:28 PM
