Turning off the rear cylinder - Road Glide Forums
post #1 of 23 (permalink) Old 07-22-2015, 01:30 PM Thread Starter
Citykid's Avatar
Okay, at a stop you roll the throttle forward for a second or two. Rear cylinder is shut down. (Cruise Control light is amber)
If you let go of the throttle and the cruise control light goes out, is the rear still shut down? (No throttle given.)
If you roll the throttle forward again the cylinder is turned on again (Cruise Control light is green).
While doing all this I can not sence, hear, feel any engine change. Is the cylinder shut down ONLY when holding the throttle forward?
Citykid is offline
post #2 of 23 (permalink) Old 07-22-2015, 01:47 PM
I believe that only enables/disables EITMS, aka parade-mode
tOSUSteve is offline
post #3 of 23 (permalink) Old 07-22-2015, 02:08 PM
wjco9's Avatar
When the light goes green you enable the EITMS, but the rear cylinder only sits down above a certain temp, you will know when it shuts down
Live to Ride
Ride to Eat
wjco9 is offline
post #4 of 23 (permalink) Old 07-22-2015, 02:48 PM
its hot enough today that if you get on the LIE and sit in traffic you will hear it come on!
2013 RGU, black of course....
y2kflhr is offline
post #5 of 23 (permalink) Old 07-22-2015, 03:29 PM
skratch's Avatar
exactly. you can not 'force' your bike into eitms. only enable/disable it. if it is enabled, there are certain parameters that must be met in order for it to go into eitms mode. if any of those parameters are not there, no eitms.
also, the parameters are different for the 2013 and below models as compared to the 2014 and up. look in your owners manual for eitms, it will explain it to you fully.
skratch is offline
post #6 of 23 (permalink) Old 07-22-2015, 05:26 PM
I don't have the EITMS on my bike anymore because the T-max tuner doesn't support it.
But from what I remember you have to roll the throttle forward and let the cruise light blink green 4 or 5 times to enable the EITMS and you have to roll the throttle forward and have the cruise light blink red 4 or 5 time to disable the EITMS. You can check and see if the EITMS is enabled/disabled by rolling the throttle forward for a second and the cruise light will be either green or red which will indicate the status of the EITMS.
When the EITMS is activated the rear cylinder will shut down when the front cylinder head temp reaches around 290 fahrenheit degrees and the bike is at a idle.
post #7 of 23 (permalink) Old 07-22-2015, 10:34 PM
Bender15's Avatar
What year bike are you doing this on? My 15 its all on the Infotainment. Nothing to do with the cruise control light
Bender15 is offline
post #8 of 23 (permalink) Old 07-23-2015, 07:57 AM
HogWild's Avatar
It's kinda like your cruise switch. It turns the system on but doesn't activate it. I don't remember the specific numbers but its something like this: Bike has to be in first or second gear, below 1200 rpm's and a certain temp. Then it activates itself and cuts the fuel off to the rear cylinder. If it activates, you'll know it. A little throttle to raise the rpm's will deactivate it.
HogWild is offline
post #9 of 23 (permalink) Old 07-23-2015, 09:57 AM
The bike doesn't have the be in gear for the EITMS to work. The bike could be in neutral too, and as long as the EITMS is turned on and the front cylinder head temp is 290 Fahrenheit degrees or more and the engine is at a idle the rear cylinder will shut down.
post #10 of 23 (permalink) Old 07-23-2015, 10:54 AM
skratch's Avatar
the rushmore bikes have changed the parameters. it is no longer tied to front cylinder head temp, it is now ambient temp. i believe 80* is the threshold. many folks with the rushmore bikes have reported that the eitms seems to kick in way early......
skratch is offline
Radio turning on while bike is off jwish76 Troubleshooting for Road Glides 2 09-14-2017 10:49 AM
Harley LED mirrors. One keeps turning off when in gear... bear25314 *General Road Glide Discussions/Pictures 7 01-27-2015 02:38 AM
Turning off AVC Othello7213 Audio 2 11-04-2014 04:05 AM
Turning light red lens covers falling off bear25314 *General Road Glide Discussions/Pictures 4 06-23-2014 09:02 PM
CVO Hydraulic Clutch Cylinder and Master Cylinder. tech643 Parts for Sale 3 04-29-2014 12:07 PM
