power vision/gauges - Road Glide Forums
post #1 of 5 (permalink) Old 08-04-2015, 08:41 PM Thread Starter
power vision/gauges
hello is there anyway to monitor oil pressure/temp with the power vision???? this tuner is awesome in what it can do! wana keep tabs on oil pressure! thanks
rebeltitanfan63 is offline
post #2 of 5 (permalink) Old 08-05-2015, 10:40 AM
EFI tuning and Exhaust Expert
fuelmoto's Avatar
Unfortunately oil pressure is not a channel on the ECM's databus
Jamie Long / Fuel Moto USA
Contact 920-423-3309
Email
fuelmoto is offline
post #3 of 5 (permalink) Old 08-05-2015, 11:23 AM
tdkkart's Avatar
If it's not on the databus, how does my '15 CVO show it on the info screen of the Infotainment system?? Shows ambient temp, oil pressure and EITMS enabled/disabled.
Push the front end of the right turn signal button, small "i" with the circle.
tdkkart is offline
post #4 of 5 (permalink) Old 08-05-2015, 01:17 PM
HellInABucket's Avatar
Two possibilities. 1) its an analog signal, and on your 15 it gets converted to digital to display on the screen, or 2) his bike is older than your 15. 14+ bikes use a CANBus system which monitors a lot more telemetry.
2018 FLTRU
Roll away the dew...
HellInABucket is offline
post #5 of 5 (permalink) Old 08-05-2015, 01:17 PM Thread Starter
thanks a million jamie!!!! getting the pv set up to my bike and all i can say is wow!!!!!!!!!!! put your map for my specks on there then tweaked the fuel and wow! NO popping deceling and smoother idle as i up that just a bit; engine seems to be cooler with me wearing shorts! once again thanks and when it time for work i can return to stock for dealer! happy customer here!!!!!!!!
$799 Power Package Street Outlaw mufflers, Power Vision, FM Stage 1 AC fuelmoto Fuel Moto 7 06-16-2018 02:37 PM
LED's, power commander, power vision, and other items for touring models. Gasitman Parts for Sale 5 08-23-2014 12:29 AM
Power Vision Gauges ZAKMANDO ECM/Fuel Management systems 4 03-15-2013 08:08 AM
New tuner from Dynojet - "Power Vision" 4getNo1 ECM/Fuel Management systems 103 10-30-2012 05:25 PM
Power Command Power Vision problem help! BigDave55 ECM/Fuel Management systems 11 08-06-2011 07:21 AM
