no baffles - Road Glide Forums
post #1 of 4 (permalink) Old 08-19-2015, 04:18 PM Thread Starter
no baffles
i have a map from jamie at fuel moto on my power vision i have tweaked it a little completely satisfied! i wana run w/o my baffles some i need to know what would i need to adjust for the loss of back pressure from the baffles????
rebeltitanfan63 is offline
post #2 of 4 (permalink) Old 08-22-2015, 05:32 PM
bcbuch's Avatar
You might want to consider adding a set of torque cones if you are going to be pulling the baffles. Fairly cheap investment and they don't take to long to install. They will give you back some of your mid and restrict at the head not back in the pipe where other leaks can still cause loss. Just a thought. Pair them with an oversized baffle they work pretty well. I had a set in my 09 RoadKing with 4 inch Rinehearts with 2 1/2 inch baffles on stock no cat headpipes. Had a Ness Big Sucker stage 1 intake, running on stock Delphi ecm. It worked fine.
bcbuch is offline
post #3 of 4 (permalink) Old 08-22-2015, 07:48 PM
IMHO, it's not a good idea. You'll lose torque.
2011 FLTRX 103 Sedona Orange
Hillglide is offline
post #4 of 4 (permalink) Old 08-22-2015, 10:07 PM
bcbuch's Avatar
If louder is the goal get true dual head pipes and a good set of slipons, put a S/E stage 1 air intake on it, and buy the S/E tuner for the bike.
These aren't Hondas that you just slap baffles in and out of to make them loud when you want. You pull the baffles then you need to adjust the A/F mix and add some restriction to the pipes ie torque cones and oversized baffles. When you put them back in you need to adjust again.
At the end of the day a set of pipes matched to the bike either has the sound or it doesn't. Pulling baffles for the most part is loud and sounds like shit, especially on a bagger. Bagger slip ons are generally in the 3 to 4 in inch diameter. When you pull the baffles they tend to have a loud metal tin can ringy sound.
The other thing to take into consideration is the cat. If you are running the stock head pipes they have a cat in them that is already choking the crap put of the bike and causing the bike to run leaner and hotter than it needs to. Pulling the baffles on a bike still running the cat isn't going to help much. The cat by itself is killing the sound.
bcbuch is offline
Passenger floorboard mounts. No spring, no ball. Mounts only.40.00 shipped neverdone Sold 1 05-13-2014 06:57 PM
Grinding out baffles and adding Fullsac baffles in CVO cans landshark *General Road Glide Discussions/Pictures 6 03-10-2013 10:19 PM
No 6th gear light, no cruise scsharp2260 ECM/Fuel Management systems 5 01-17-2013 02:14 PM
4" Rineharts...no baffles question Coolbluestreak Intake and Exhaust 4 03-10-2012 07:25 AM
No Cruise, No Brake Lights , engine light and lots of codes DonJulio Troubleshooting for Road Glides 4 07-24-2011 05:02 PM
