SEPRT Stage1 Base Map - Road Glide Forums
post #1 of 6 (permalink) Old 09-01-2015, 04:16 PM Thread Starter
I'm new to tuning but prefer to do this myself so I learn as I go. I have 2013 FLTRX and have a S&S stealth air cleaner and a D&D H-pipe coming (will use my current FP Outlaw slip on's for now).
I haven't done anything yet, but do not see very specific base maps in the SEPRT software to choose from.
With OE Camshaft, really only Configuration 1580 (SE Air Cleaner, Race Exhaust, ACR disabled) seems close. When I load this though and compare it to the Original, I see no difference at all to either the VE or AFR tables.
Is this where you guys start for a stage-1 'autotune' session ?
THANKS
sifugumba is offline
post #2 of 6 (permalink) Old 09-01-2015, 05:52 PM Thread Starter
Sorry, I meant DRAGOS H-Pipe is coming (Frank is going to kill me) !
post #3 of 6 (permalink) Old 09-01-2015, 06:48 PM
That's pretty much how I started. I would keep an eye on the timing tables when doing auto tune. For some reason I've had it retard timing which really starts screwing with things. My guess is the knock sensor is going off cause the autotune has it lean to begin with
CashMoney is offline
post #4 of 6 (permalink) Old 09-01-2015, 08:13 PM Thread Starter
Thanks. I'm also going to ask the dealership. At one point they discussed doing a stage1 download for me (vs a full dyno session).
They wanted to charge for this, of course, but I can't help but wonder what this meant since the VE and AFR tables for this setup are exactly the same as what's on the bike now. Seems that it wouldn't do anything by just downloading it as is.
Can't help but think I'm missing something (like a secret source of SEPRT maps beyond what comes with their software)
post #5 of 6 (permalink) Old 09-02-2015, 07:37 PM Thread Starter
Stopped by the dealership today, 4 guys behind the service desk. I asked them which map they started with for a Stage 1 tune; basic answer was 'you need to Dyno'. When I opened the application and pointed to Configuration 1800 they said, 'yeah, that's the one we use'. Then I showed him 1580 and he said 'probably pretty much the same'.
Pretty sure the guys I was talking to had no idea.
Application: 2010-2013 Touring
Configuration: 1800 Stage1
Components:
-SE or CVO air cleaner
-SE exhaust
Configuration: 1580 Stage1
Components:
- SE Air Cleaner or Heavy Breather Kit
- Race Exhaust
-ACR disabled
post #6 of 6 (permalink) Old 09-02-2015, 07:53 PM
there should be some files for 1690 cc and a harley screamin eagle exhaust with stock cam, thats probably where i'd start
Stage1 Completed Cali-rider Intake and Exhaust 13 04-04-2016 01:09 PM
15 RG A base model as base can be..... maddmoe Audio 9 03-15-2015 07:30 PM
SEPRT Obsevations Scoop ECM/Fuel Management systems 11 06-19-2013 09:08 AM
Power Vision and Stage1 Air Kit Install - 2011 RGC wachuko Fuel Moto 13 01-19-2012 07:34 PM
