First attempt at V TUNE - Road Glide Forums
post #1 of 7 (permalink) Old 09-18-2010, 11:16 PM Thread Starter
SafetyMan's Avatar
If I read everything right....
This ain't too bad a start...
Tomorrow, if I didn't crater K ren's laptop, I'll do another....
WSFFWS
2B1ASK1
SafetyMan is offline
post #2 of 7 (permalink) Old 09-19-2010, 03:22 PM Thread Starter
SafetyMan's Avatar
OK... here's the result of my data run today, and my final map....
....for now.
WSFFWS
2B1ASK1
post #3 of 7 (permalink) Old 11-07-2010, 08:44 PM
And having reviewed the results, I'm curious as to what you did with them. You didn't mention what the year, size, or mods of the engine is. I've been reading the manual on my TTS, and I'm getting cross-eyed trying to figure this stuff out. Sure have been a lot changes to that "brain box" over the last couple years. And when they start talking "Lamba," I go into brain-melt-down.
2004 XL1200C
2011 FLTRU
ronn39 is offline
post #4 of 7 (permalink) Old 11-08-2010, 03:34 AM
SLOglide's Avatar
Unless you are an engineer don't worry about the "how it works" stuff like lamba.
Having said that you do have to start with a program that is fairly close, the VE tuning rides are just gathering data to tune the fuel schedule. Just follow the directions, the program blends all those results together itself and writes a new map all on it's own.
John not in Saudi any more!!, mortgage in Cal.
2009 Road Glide; HoboCoastie's tank lift, Andrews 48H cams, TTS, Progressive 940's, a bit of chrome.
SLOglide is offline
post #5 of 7 (permalink) Old 11-24-2010, 09:32 PM
Gadgetech's Avatar
Doesn't necessarily nail down engine size but the image in the second post shows a 2011 FLTRU.
2017 RGU Black Quartz
2014 Ducati Multistrada Granturismo
Gadgetech is offline
post #6 of 7 (permalink) Old 11-27-2010, 08:15 AM
Deuce Bigelow's Avatar
looks like you're off to a GREAT start!
just need to try and get more readings in the lower and higher MAP ranges... the lower ones are harder because you have to really try and load down the bike.. try going up a steep hill at lower RPM ranges a few times...
2010 FLTRX
Deuce Bigelow is offline
post #7 of 7 (permalink) Old 11-27-2010, 08:17 AM
How does the motor feel after the final V-Tune??
2010 FLTRX
Gliding set to Music....my first attempt.... memikeni Videos 14 09-21-2013 11:51 AM
First attempt at maintenance...all good!! SharkBite *General Road Glide Discussions/Pictures 14 01-08-2013 01:49 PM
1st Attempt @ Video Neano62 Audio 15 12-16-2011 07:57 AM
Picture Attempt Hogrider 21 New Members Welcome Area 7 09-10-2011 11:07 PM
