Tuner for a 2001 RG ??? - Road Glide Forums
 2Likes
post #1 of 12 (permalink) Old 09-23-2015, 07:28 PM Thread Starter
Ginee13's Avatar
I have been looking for a power comander, dynojet or some sort of tuner for a 2001 RG with no real luck. Does anyone know of a good unit I can get and use.
2001 Road Glide Black with blue to gray flames
Ginee13 is offline
post #2 of 12 (permalink) Old 09-23-2015, 07:55 PM
Clutch1's Avatar
I have a power commander 3 on my 04 from fuel moto and their map for it. Gave me a solid base line to work from.
Ginee13 likes this.
Clutch1 is offline
post #3 of 12 (permalink) Old 09-23-2015, 08:04 PM
^^ try an find a PC lll, many utube easy and proven, even a used one.
reds4 is offline
post #4 of 12 (permalink) Old 09-23-2015, 08:23 PM Thread Starter
Ginee13's Avatar
Looking at the PC III it claims its for 2003 Harley's and up.
Ginee13 is offline
post #5 of 12 (permalink) Old 09-23-2015, 09:30 PM
Your 01 FI?, of course
reds4 is offline
post #6 of 12 (permalink) Old 09-23-2015, 09:49 PM
Triplej's Avatar
Just to name a few, you have the Powercommander PC-V # 15-040 and the Powercommander III # 802-511 as options as well as a few controllers offered from Dobeck Performance to consider.
Harley Davidson All Big Twins - Dobeck Performance Products: EFI Controllers, AFR Gauge
Triplej is offline
post #7 of 12 (permalink) Old 09-29-2015, 12:31 PM
EFI tuning and Exhaust Expert
fuelmoto's Avatar
Power Commander III has been discontinued. It has been replaced with Power Commander V (PC-V) in all applications.
Jamie Long / Fuel Moto USA
Contact 920-423-3309
Email
fuelmoto is offline
post #8 of 12 (permalink) Old 09-29-2015, 01:29 PM
You may want to get in touch directly with Power Commander or, as much as it may hurt the wallet, get in touch with a dealership that does some trusted dyno tuning in your area. The issue you're running into is that you have the early Magneti Marelli fuel injection system. I was talking with a guy down at the Tail of the Dragon last year who had an early Ultra Classic with the MM injection and he said he had quite the time finding something as well. He said he had found an old Power Commander setup that was made for that but I honestly have no idea if those are still out there. Best of luck and I hope someone else on here has a more concrete direction for you.
2006 Black Pearl, High flow A/C, true duals w/ Fulsac cored SE mufflers, Thundermax, Ohlins 2-2b...more to follow?
JStegs63 is offline
post #9 of 12 (permalink) Old 09-30-2015, 09:18 AM
fuelmoto's Avatar
Not hard to find at all. The Dynojet Power Commander V is the latest product that is readily available. Part # 15-040. We have plenty of them in stock, here is a link with more info Dynojet - Power Commander V - HAR TOURING 97-01
Email
fuelmoto is offline
post #10 of 12 (permalink) Old 09-30-2015, 11:28 AM
Thumbs up
I stand corrected, haha. I knew this forum would turn up more information that I was aware of.
JStegs63 is offline
Starter Problem 2001 RG TC88 Lunchboxx Troubleshooting for Road Glides 6 11-16-2015 09:17 AM
2001 RG, which Heritage bars fit? Kobrak Controls & Handlebars 3 12-03-2013 07:26 AM
looking for a Stabilizer for a 2001 CVO RG 2001CVORG *General Road Glide Discussions/Pictures 6 09-05-2013 12:21 PM
Replacement gauges for 2001 RG ?? caboverbob Do-IT-Yourself 1 12-20-2012 07:02 AM
2006 RG and 2001 UltClassis BLACKHAWK Audio 2 10-21-2011 06:03 AM
