Wide band O2 sensors - Road Glide Forums
post #1 of 3 (permalink) Old 09-22-2010, 08:03 AM Thread Starter
Anybody change out the O2 sensors and leave evrything else stock? What was the result?
Glideliner is offline
post #2 of 3 (permalink) Old 09-23-2010, 01:04 AM
My understanding of the factory ECM, is that it goes out of closed loop mode, above a certain point. Not sure if it's just RPM, or a combo of RPM, throttle position, etc... Don't think a wide band O2 sniffer would do anything meaningful, unless you went with an aftermarket ECM or add on, that can utilize the info?
Jeff
akjeff is offline
post #3 of 3 (permalink) Old 09-24-2010, 04:13 PM
Fcatory sensor has a 12 mm thread on 2010 and newer
Wide band sensor has 18mm and is much longer
will not fit
ROADEAGLE is offline
Wide Band O2 Placement???? mustangoutcast ECM/Fuel Management systems 4 02-23-2015 05:12 PM
Anyone running the wide band sensors with the Power Vision? Fire-Medic ECM/Fuel Management systems 18 03-29-2014 07:52 PM
Thundermax not finding O2 sensors 07RoadGlide ECM/Fuel Management systems 19 04-14-2013 04:22 PM
V&H Power Duals & O2 sensors KIWIHOG Intake and Exhaust 11 03-28-2012 03:20 PM
What's the difference between Wide Band and Narrow Band O2 sensors? Timinfla2 Intake and Exhaust 4 04-26-2011 01:23 PM
