Cats - Road Glide Forums
 2Likes
  • 2 Post By JacktheBagger
post #1 of 10 (permalink) Old 11-24-2015, 11:53 PM Thread Starter
Ouijonbu's Avatar
Cats
Riders,
What does removing the cats do, does it throw a code? Pro-con. I removed my baffles, will removing cats make it noticeably improved ?
[SIGPIC]2015 RGS and 2011 ZX14-muzzy pipes, PC-5 w/AT. Hyperlink steering damper, 6" in the rear, -1 in front+2 in rear, secondary flies gone, second fan welded, tires have balance beads instead of weights. Nitro instead of air. K&N AF
Ouijonbu is offline
post #2 of 10 (permalink) Old 11-25-2015, 04:17 AM
FDR's RGC's Avatar
Less heat,no codes. Use the search,it's your friend.
FDR's RGC is online now
post #3 of 10 (permalink) Old 11-25-2015, 08:46 AM
You will lose a lot of low end torque running wide open pipes.
post #4 of 10 (permalink) Old 11-25-2015, 10:29 AM
JacktheBagger's Avatar
Put the baffles back in and take the cats out . I drilled mine out , others have it cut open and removed and welded back up ..
No codes , sounds 'like it's supposed to' according to my spousal unit , doesn't feel choked down all the time , runs cooler .
I gained 386.74598 ft lbs of torque at 174859.652315 rpm and 350 hp at 164581.602658 rpm ..
JtB
Big_gary and nsbohall like this.
2011 Ultra
JacktheBagger is offline
post #5 of 10 (permalink) Old 11-25-2015, 11:17 AM
mouser58's Avatar
I replaced my head pipes with Power duals, no lights..I just called V&H, got the new numbers..
2012 Ultra...Stage 1...Vance & Hines Power Duals,SE Night Sticks, V&H Digital, Stock air box with larger fliter..
mouser58 is offline
post #6 of 10 (permalink) Old 11-27-2015, 10:34 AM
Sleepybagger's Avatar
My 103 Stage IV picked up 8 horses and 10 torque using same mufflers with a FM2-1-2.
Imagine trying to exhale with a sock on your mouth.
2015 113" 125/131
Sleepybagger is offline
post #7 of 10 (permalink) Old 11-27-2015, 10:46 AM
whose sock ??
clean or dirty ??
JtB
2011 Ultra
post #8 of 10 (permalink) Old 11-27-2015, 10:46 AM
hook's Avatar
Since when is anything mandated by the epa a good thing...
+1 on no codes and less heat
hook is offline
post #9 of 10 (permalink) Old 11-27-2015, 07:02 PM
'05Train's Avatar
At Stage 1 power levels, not a huge bottleneck. The bike will run cooler, but it will also run louder.
'05Train is offline
post #10 of 10 (permalink) Old 11-28-2015, 01:47 PM
9over's Avatar
Louder and cooler.
9over is offline
Rinehart Slip-ons w/ Cats STREAK Intake and Exhaust 3 04-30-2011 05:59 PM
Cats IN the pipe? SKULLZ Intake and Exhaust 28 04-25-2011 11:06 AM
2011 RG with CATS or without GLYDDN11 Intake and Exhaust 39 02-13-2011 06:32 PM
New supertrapp and Kerker Stout for cats. jeff Intake and Exhaust 0 01-28-2011 11:05 AM
removing cats from cvo bikes digga25 Intake and Exhaust 7 09-22-2010 10:02 AM
