TTS Map needed - Road Glide Forums
post #1 of 13 (permalink) Old 12-19-2015, 05:54 PM Thread Starter
TTS Map needed
Have a 2010 rg 103 with 10.5.1 pistons 574 fueling cams, bee hive valve springs,arlen ness big sucker air cleaner,vance and hines 2 into 1 pro pipe.The shop that did the work said he used a base map bike runs ok just when it's hot it idles around 800 rpm.I see where people talk about different maps but how do you find the maps?Do the maps come up when hooked up to bike haven't done that yet.Any help would be appreciated.
steve2100 is offline
post #2 of 13 (permalink) Old 12-19-2015, 06:12 PM Thread Starter
This is what i have done so far replaced throttle body and injectors,coil and plug wires,fuel filter,plugs going to change fuel pressure regulator after that i would like to try another map.Like i said bike runs ok not pinging backfiring only problem is the idle it don't quit but shakes a lot at 800 rpm.Also changed 02 sensors and the temp.sensor in the head.
post #3 of 13 (permalink) Old 12-20-2015, 06:57 AM Thread Starter
bump
post #4 of 13 (permalink) Old 12-20-2015, 07:10 AM
Ohiobellboy's Avatar
Did he just load a canned map in it or did he actually tune it on a dyno?
A.K.A OBB
Ohiobellboy is offline
post #5 of 13 (permalink) Old 12-20-2015, 07:13 AM Thread Starter
Just a canned map but i can't find the maps i saw the one's on the tts site but they are buy vin number.
post #6 of 13 (permalink) Old 12-20-2015, 11:04 AM
Email Steve Cole out there at TTS and see what he says would be a better map for you. Or pay a reputable tuner to finish the job.
A.K.A OBB
post #7 of 13 (permalink) Old 12-20-2015, 11:21 AM Thread Starter
Ok thanks going to change pressure regulator read where someone had about the same problem with low idle.If that don't work then i will change tune or try and find a good tuner in my area.
post #8 of 13 (permalink) Old 12-21-2015, 06:55 AM Thread Starter
bump
post #9 of 13 (permalink) Old 12-21-2015, 09:09 AM
Desertwndrr's Avatar
Quit changing stuff. Low idle is adjusted in the map. You really need to get a full dyno tune. In the interim I can help with the idle issue. I'll PM you my email address. Send me your map to tweak.
Better yet, get hold of these guys in Fredricksburg. They will make your bike perfect.
Wide Open Cycles - Home
2019 RGS, 2016 RGS, 2015 RGS
Desertwndrr is offline
post #10 of 13 (permalink) Old 12-21-2015, 05:56 PM
That's the name of the place I was thinking of. Couldn't find it though.
A.K.A OBB
'18 114-in Stage=4 with TTS cams and TTS tuner Sharkbreath Dyno Results 12 12-16-2017 10:02 AM
MasterTune (TTS) MAP Needed To Get Me Until Dyno Bdawson266 Map Section 16 04-26-2015 04:21 PM
TTS map needed, please Colin1966 Map Section 0 01-07-2013 09:00 AM
TTS MASTERTUNE w/ Software and TTS USB cable. Raiderse Classifieds Archive (3 months old+) 0 05-17-2012 04:08 AM
TTS MasterTune Map to stop Ping and high heat 2011 RGU? Raiderse ECM/Fuel Management systems 15 05-10-2012 01:52 PM
