computer cant/wont open winpv files - Road Glide Forums
post #1 of 7 (permalink) Old 12-24-2015, 08:28 PM Thread Starter
my computer says the files are not supported or are damaged???? anyone else have this problem! thanks in advance
harleyfltrxman is offline
post #2 of 7 (permalink) Old 12-24-2015, 09:17 PM
skratch's Avatar
nope. try sending me one of your files and i'll see if i can open it on my computer.
skratch is offline
post #3 of 7 (permalink) Old 12-25-2015, 07:20 AM
bucketlisthd's Avatar
I had the same problem with a Fuel Moto map. I called them, gave them access to my computer, and they fixed it. I'd call whoever sent you the map.
'15 Roadglide Special
'87 FXR 100"
'79 Goldwing cafe
bucketlisthd is offline
post #4 of 7 (permalink) Old 12-25-2015, 08:24 AM
Wharf Rat's Avatar
Sounds like an association issue. Is that file type associated with an application on your computer? If not, you just need to tell the computer what application to use with it.
Like I told you. What I said. Steal your face right off your head.
Wharf Rat is offline
post #5 of 7 (permalink) Old 12-28-2015, 09:52 AM
EFI tuning and Exhaust Expert
fuelmoto's Avatar
Please post exactly which files you are opening, also make sure you open the files within the WinPv sofware directly
Jamie Long / Fuel Moto USA
Contact 920-423-3309
Email
fuelmoto is offline
post #6 of 7 (permalink) Old 01-03-2016, 08:27 PM
skratch's Avatar
did you ever get any resolution to this issue?
skratch is offline
post #7 of 7 (permalink) Old 01-03-2016, 10:32 PM
fuelmoto's Avatar
My post to the OP on another forum:
You are saving .pvv files which are Value Files. These are corrected VE tables populated by running Auto Tune, they are not Log Files. To do a log you must use the start/stop log button from any gauge screen or from the auto tune green screen. They are automatically saved as a .csv file and are numbered in sequence. You will retrieve them using Get Log I the WinPv software
Email
fuelmoto is offline
The Donk Handle Bar Files are Sweeet! ammojeff Controls & Handlebars 6 06-02-2013 06:35 PM
So i cant adj bass treb and balance cant start in gear with clutch in milkman48 Controls & Handlebars 1 02-26-2013 10:11 AM
winpv for dummies 08gezzer Fuel Moto 1 12-09-2012 10:16 PM
Damn computer problems - computer experts? CHAINSAW General Off-Topic Discussions 28 05-23-2012 02:47 AM
WinPV question/problem ameleo ECM/Fuel Management systems 2 07-11-2011 01:24 PM
