Thundermax vs FP3 - Road Glide Forums
 4Likes
post #1 of 12 (permalink) Old 01-03-2016, 10:33 PM Thread Starter
Shaner87's Avatar
Thundermax vs FP3
Okay, so I have read a lot on both tuners. I actually had a Thundermax on my 2008 Ultra. The only thing I am looking at is that the FP3 with auto tuner via bluetooth and app seemingly does the same thing overall as the Thundermax. But I could be very wrong about this. Would just like a comparison of the two, pros and cons, etc. Thanks in advance.
Shaner87 is offline
post #2 of 12 (permalink) Old 01-03-2016, 11:30 PM
hifiho's Avatar
I've run both. I've still got the TMax, w/ Autotune on my V-Rod, and the FFP3 on my 'Glide.
I've had a steady stream of reliability issues with the TMax. NEVER been able to get a tune that isn't too lean or far too rich. On the open road, it runs well, and is for the most part problem-free. It HAS jacked the gauge cluster while riding. All warning lamps light up, and the tach, speedo, and fuel gauge all stop working. I know that's relative the the TMax ECU. This requires a few cycles of the ignition switch, and it seems to heal itself. Occasionally, on a cold start- it will display "ERR" in the lcd window, and refuses to start.
In town, it's never run right. Backfires, belches, and has a nasty idle. I intend to re-install the SERT and HD ECU, then pay for a dyno-tune.
The FFP3 is a gem. Never had a backfire, rode about 3k miles, and the plugs look fine. I've played with the Bluetooth via smartphone, and it seems to connect fine. No need to mess with the tune, but it will display error codes (if there are any) upon bootup. And display a few other parameters that your stock gauges don't display. Free install and map load while at Sturgis last summer. Runs like a top, and the map they loaded definitely bumped the performance up a bit. On the fly-by-wire bikes, throttle response is kind of hard to gauge vs. throttle cable. I know the sensitivity of the sensor in the TBW unit can be adjusted in the FFP. But climbing hills on interstates, I could definitely feel a little extra muscle while passing trucks, etc.
I've got nothing bad to say about the FFP3. I paid a lot less for it vs. the TMax as well.
bobbybones likes this.
'15 Road Glide Special...'08 Night Rod Special...'04 Stage 4 113 CI Softail Deuce (Beast Mode)
hifiho is offline
post #3 of 12 (permalink) Old 01-03-2016, 11:33 PM
SMOKENJOE's Avatar
NICE VIDEO ON THAT PRODUCT
Vance & Hines | Fuelpak FP3 Video's
SMOKENJOE is offline
post #4 of 12 (permalink) Old 01-04-2016, 01:36 AM Thread Starter
Shaner87's Avatar
Hifi- did you notice a bad drop in fuel economy with your tmax? I did on my 08 and that's what is making me so hesitant about putting one on my 15 RGS.
Shaner87 is offline
post #5 of 12 (permalink) Old 01-04-2016, 06:44 AM
Smarty's Avatar
On my o4 Batwing Ultra with a highly modified engine I used the t-max instead of dyno tuning. I pretty well know this tuner frontwards and backwards. Without fail, when I would get the tune and timing like I wanted it, it would start out with very good gas mileage, around 42-43 mpg, then over the next few tanks of gas it would start to come down and settle in at around 33-34 mpg. I worked and worked on this and never could get it to hold the gas mileage tune. I finally gave up on it.
Smarty is offline
post #6 of 12 (permalink) Old 01-04-2016, 03:30 PM
hifiho's Avatar
As Smarty said- inconsistent runs, followed by a super-rich AFR. Mileage took a nosedive. Same tuner is compatible with the V-Rod and traditional V-Twins, which I thought odd. Same connectors, different tune I guess.
Just my $0.02. I'm sure I'll have mine for sale by spring.
hifiho is offline
post #7 of 12 (permalink) Old 01-04-2016, 03:44 PM
If you need an FP3 hit me up. I have plenty in stock and the best price around. Give me a call (818)886-6545
Drew
Smarty likes this.
HogPro is offline
post #8 of 12 (permalink) Old 01-04-2016, 06:22 PM
Sparky0426's Avatar
Running the FP3, have no problems or complaints.
2018 Ultra, Twisted Cherry
Sparky0426 is offline
post #9 of 12 (permalink) Old 04-08-2016, 01:12 PM
GeezerGlide16's Avatar
Ok I have a stupid question..... What is an FFP3?
GeezerGlide16 is offline
post #10 of 12 (permalink) Old 04-08-2016, 04:21 PM
Its Vance& Hines new fuel pack/ tuner.
Fuelpak
GeezerGlide16 likes this.
Stock vs Arnott vs Legends vs HD Premium SEUGOT1 Suspensions 15 04-25-2017 10:10 AM
Thundermax vs DynoVision vs PwrPro Black vs FP3 stillsoldier4christ ECM/Fuel Management systems 16 10-01-2016 12:42 AM
Anyone using the V&H FP3 garbage cannon ECM/Fuel Management systems 23 09-07-2015 08:46 AM
V&H Fuelpak FP3 available from Fuel Moto fuelmoto Fuel Moto 10 03-31-2015 09:13 AM
Vance and Hines FP3 12fltrx ECM/Fuel Management systems 1 09-01-2014 10:45 PM
