Which FP3 Map with American Custom Exhaust? - Road Glide Forums
 2Likes
  • 1 Post By ! rock103 !
  • 1 Post By Fatglide72
post #1 of 10 (permalink) Old 01-09-2016, 08:40 AM Thread Starter
Padrel's Avatar
Got the FP3, K&N air filter, American Custom Bomber mufflers with the Powerflex header. Currently have the K&N filter installed and am running the FP3 map for stock pipes.
My question is: what base map should I run after installing the AC mufflers and Powerflex header? Auto-tune is probably going to happen when I can put some miles on it, but I have to start with a base map. Question is, which one?
I'd appreciate any advice.
Bob
MSgt, USAF (Retired)
2016 FLTRU
Padrel is offline
post #2 of 10 (permalink) Old 01-09-2016, 09:18 AM
! rock103 !'s Avatar
I'd give the crew at Vance and Hines a shout and see what they suggest. With the FP3 they can download a custom tune right to your module. They can even log into your module if attached to the bike to see how your bike is running in realtime.
Sparky0426 likes this.
USMC 1990-2000 (0311/6017)
! rock103 ! is offline
post #3 of 10 (permalink) Old 01-09-2016, 01:08 PM Thread Starter
Padrel's Avatar
Seems like a good way to go and probably the safest bet. Thanks.
Bob
2016 FLTRU
Padrel is offline
post #4 of 10 (permalink) Old 05-21-2016, 08:10 AM
SteveH's Avatar
How did you make out with the tune?
2017 Road Glide Ultra, Black Quartz, CD leds & flashers, Electra Glo Keystone Auxiliary LED Run/Brake/Turn Lamps, Rinehart 4.5" slip-ons, T-Bag lid covers, LRS 15" Thresher, Powder coated wheels
SteveH is offline
post #5 of 10 (permalink) Old 05-21-2016, 02:56 PM Thread Starter
Padrel's Avatar
Still on auto tune but it's running fine. Need more data for the higher rpms but will give it a couple more tanks.
Padrel is offline
post #6 of 10 (permalink) Old 05-23-2016, 09:23 AM
Fatglide72's Avatar
Do you like the American Custom Exhaust?
conn-e-rot likes this.
Fatglide72 is offline
post #7 of 10 (permalink) Old 05-31-2016, 07:44 AM
SteveH's Avatar
Padrel, so what base map did you end up starting with?
SteveH is offline
post #8 of 10 (permalink) Old 06-01-2016, 02:09 AM Thread Starter
Padrel's Avatar
Yes, I like the American Custom exhaust. The first one they sent was slightly off, so I called AC and they sent me a replacement right away, and it fit fine.
As for the base map, I used the Vance and Hines High Output with Power Duals, Standard Baffle.
Bob
2016 FLTRU
Padrel is offline
post #9 of 10 (permalink) Old 06-03-2016, 09:44 AM
SteveH's Avatar
Got my FP3 setup. Real easy. I have American Custom mufflers Loaded the HD stock map, set the moderate throttle level and the low decel pop.
WOW. Much smoother, much less lag.
Now I have it in Autotune mode.
SteveH is offline
post #10 of 10 (permalink) Old 06-08-2016, 01:51 PM
SteveH's Avatar
Applied first Autotune and the bike just keeps getting better. This thing is great!
SteveH is offline
FP3 canned map advice canukHD ECM/Fuel Management systems 6 05-16-2018 01:30 PM
red P light on after fp3 map added riggersxj ECM/Fuel Management systems 5 06-09-2017 04:59 PM
Fp3 map question. RFG7680 ECM/Fuel Management systems 2 07-31-2016 07:52 PM
FP3 Map Mainiac Mark Intake and Exhaust 2 10-24-2015 08:46 AM
fp3 map scrapper Intake and Exhaust 9 09-17-2015 12:59 PM
