Heat! - Road Glide Forums
post #1 of 9 (permalink) Old 10-05-2010, 09:11 AM Thread Starter
Custom Seat Moderator
BadX's Avatar
Heat!
I have seen post in the past about heat issues but have never experianced anything till now. Here is my setup.
Vance and Hines HO 2-1 exhaust.
PM Super Gas intake
Power Commander V from Fuel Moto with their map for my setup.
I emailed Jamie about the heat and every once and a while I'll get a back fire. He said to get the heat shields which I did and they do help a little but damn that rear exhaust is freaking burning up my inner thigh when stopped.
Any ideas?
BadX is offline
post #2 of 9 (permalink) Old 10-05-2010, 11:30 AM
ScooterDog's Avatar
Most of us have been there. Some say synthetic oil helps, but not by much. If you have the leg shields and a proper tune, then the only other option is an oil cooler. They're pricey, but they do the trick.
ScooterDog is offline
post #3 of 9 (permalink) Old 10-05-2010, 11:46 AM
1BigGuy's Avatar
Is this a new thing or has it been going on for a while on your bike or was this while you were in Florida last week? hehe
Oil coolers help some, but they are not everything. I've got one on my bike now, but still have the OEM headpipe and can feel the heat. Fuelmoto's 2 into 1 head pipes are on back order, so I'm waiting on that to replace mine along with a PCV, then maybe it will get better for me.
2010 FLTRX Black Denim
2007 FLSTN Vivid Black
1BigGuy is offline
post #4 of 9 (permalink) Old 10-05-2010, 01:58 PM
joke's Avatar
I did the FL-Xied O2 sensor thing and while you can still feel the heat it's not burning my leg off.
2009 Mirage Orange
joke is offline
post #5 of 9 (permalink) Old 10-05-2010, 02:16 PM
dp1961's Avatar
i went with the vance and hines dresser duals, heat pretty much gone now...
dp1961 is offline
post #6 of 9 (permalink) Old 11-28-2010, 07:53 AM
roadgliderick's Avatar
Send a message via Yahoo to roadgliderick
i went with the thundermax TBW and my heat issues ARE gone.
2011 roadglide firemist orange carlini 17 inch eval bars, C&C solo seat, paugho true duals with thunder header slip ons , oil bud oil cooler, cool sac grips, alpine cda 105 head unit, alpine type r speakers with alpine 2150 digital amp,stratum timer cover derby cover and a/c cover sinister wheels 21 up front 18 rear woods 555 cams with adjustable push rods and tmax tuner. bad dad front wrap and bad dad rear summit fender with hide-a-plate and flush mount rear LEDs arlen ness big bags.
roadgliderick is offline
post #7 of 9 (permalink) Old 11-28-2010, 08:33 AM
doc
doc's Avatar
You can try richer tune on you Powder Commander. The more fuel you add, the cooler the motor, also the lower your gas mileage. You need to find someplace in the middle you can live with.
2008 Candy Red Road Glide
TFI Controller. H-D Premium Oil Cooler. S/E Ventilator A/C. Vance & Hines 2 into 1. Bagger Brace. Wind Vest. Hogg Chopps lowers.
doc is offline
post #8 of 9 (permalink) Old 11-28-2010, 09:34 AM
hodgeaaco's Avatar
Don't know what to tell you. Most of us have been there and having done what you did already should have cooled it a little. Once I got rid of the cat pipe and added the PC5, it became bearable.
If you are still getting a backfire, it sounds like a little more tuning is in order. Try adding some fuel in the 0 TP boxes.
2010 FLTRX - "Black Plague"
hodgeaaco is offline
post #9 of 9 (permalink) Old 11-28-2010, 03:03 PM
dirtbag's Avatar
ProPipe H/O? Do you have a TC96 or 103? Also, do you have any internal modifications to the motor? Cams, etc.? I have the V/H Pro Pipe Chrome, with the PCV (with plans for the AutoTune) and a Ness Big Sucker, and the bike feels cooler than my stock exhaust did. Maybe too much O2 in and out of the motor not being completely combusted. (Does the inside of your exhaust tip look white, brown or black? Thats a good place to start.)
Gasket leaks? Im going to re-do mine this winter. (V/H says that slight popping can be a gasket leak even if it doesnt feel like it.)
I also run AMSOil 20W50/Severe Gear 75W140 (with plans for a cooler).
Im sure you have probably looked into most of this, but what you learn may help me in the future also.
2010 FLTRX - THE RED DRAGON
KCCO - CHIVE ON!
dirtbag is offline
Nightrider O2 sensor - engine heat review joke *General Road Glide Discussions/Pictures 7 09-06-2010 09:26 PM
Heat Issue dblkick Intake and Exhaust 14 08-16-2010 01:30 PM
Heat deflectors longrides Aftermarket Accessories 12 07-03-2010 06:05 PM
Heat Demon Insets ROADEAGLE Controls & Handlebars 6 05-31-2010 05:15 AM
Dealing with engine heat on the newer engines 1BigGuy *General Road Glide Discussions/Pictures 4 04-05-2010 08:02 PM
