Fp3 - Road Glide Forums
 4Likes
post #1 of 30 (permalink) Old 02-13-2016, 05:52 PM Thread Starter
Fp3
Spoke with V&H yesterday to discuss warranty concerns and ask about the additional power increase that I would see after installing the FP3 over the HD stage one download. V&H stated the only info they had regarding the FP power increase was about 5% over stock, and no info about the power increase over hd stage one. Does this sound right? Only 5% increase over stock??? that doesn't sound like much.
2015 FLTRUSE V&H dresser duals, Hi-Output Mufflers
2002 FLHTCUI 113, V&H true duals, Bassani mufflers, Still have her
mach65 is offline
post #2 of 30 (permalink) Old 02-21-2016, 07:42 AM
! rock103 !'s Avatar
Thumbs down
Mine has been having continued problems since I bought it. I have spoke elsewhere about it. Here are examples of my woes...
I'd also like to point out it has been about a month and V&H has yet to be much if any help in a resolution...
USMC 1990-2000 (0311/6017)
! rock103 ! is offline
post #3 of 30 (permalink) Old 02-24-2016, 11:30 PM
rock103 have you heard back from Vance and Hines yet? I was thinking about purchasing that unit as well but if they are having issues maybe i should look elsewhere...
Singe is offline
post #4 of 30 (permalink) Old 02-25-2016, 04:29 AM
MatteGlide15's Avatar
No offense but I've had an FP3 on my RG for the last 8 months and have had zero issues with it. I've autotuned and switched maps had no issues pairing with my phone or ECU. You will get the same response from somebody who uses a power vision or a screaming eagle tuner or a thunder max. Then read on another thread about somebody having issues with the same exact products you just heard others raving about......
No product is perfect there are gonna be defective units with anything especially dealing with electronics. All it takes is a faulty circuit board or a loose wire etc.
So when making a decision take in all the info collectively good & bad weigh in and then make a decision.
MatteGlide15 is offline
post #5 of 30 (permalink) Old 02-25-2016, 06:03 AM
As posted in another thread after posting issues elsewhere I was finally got a replacement authorized. Chris Neely from vance and Hines monitors forums and finally authorized a replacement. They backed their product. Although taking over a month to do so. The new is working with minor issues during auto tune. But is connecting better than previous unit. There has been others with same issues, so Idk why they were so adement with not replacing the unit. I think the power vision from fuel moto would be a better unit with better support. JMHO
post #6 of 30 (permalink) Old 02-25-2016, 04:28 PM
slow ride's Avatar
I have had the fp3 on my 15 since I got it, done stage 1 map it no issues, decated head pipe and mapped again no isuses, haven't done a auto tune session yet but going to as soon as I can...
tboman likes this.
slow ride is offline
post #7 of 30 (permalink) Old 02-25-2016, 06:30 PM
Guys! vance & Hines should be embarrassed! Buy a tts master and have it dyno by a qualified tuner.there is another thread with a guy who did a H.D. tire shreder kit and used (two different tuners.why?)when he could have done a 107 kit half the money with the same results. There are some great kits from fuelmoto,Drago,Gmr, axtell all great guys with great products.please do your home work it pays.
dozer23 is offline
post #8 of 30 (permalink) Old 03-16-2016, 04:24 PM
I think for the guy putting some pipes and maybe an air cleaner on his bike a dyno tune is a little over kill. I have had both the SE race tuner and the FP3 and let me tell you to be able to tune on the fly is a lot more convenient and cheaper than having to dyno tune all the time for some small upgrades. Now if your building monster motors with cams/heads/pistons/throttle bodies then that's a different story
HenryG likes this.
2016 Road Glide Charcoal Pearl. 6.5 stereo installed.
Black Thunder Header 2-1
FP3 tuner
LUCKY13 is offline
post #9 of 30 (permalink) Old 03-16-2016, 07:41 PM
I have had the FP3 on my Stock 15 RGS since Sept 15. Performance improvement was noticible. Once set up, no issues. Doing header, exhaust and a air cleaner this spring and the Map is already waiting for the upgrade. I am optimistic! I think the FP3 is an great product.
Jhl192 is offline
post #10 of 30 (permalink) Old 03-30-2016, 01:19 AM
bisonium's Avatar
I've been running my FP3 since Feb '15 with absolutely ZERO issues. It is a noticeable increase in power over stock with my power duals / 450 Titans and the Stage 1. Love the added functionality they have added as well. Remember when using auto tune to run the auto tune for at least a full tank...
2015 Road Glide Special - V&H Power Duals, V&H Titan 450 Slip-ons, V&H FuelPak3, HD Stage 1, Klock Werks 14, F47 12" Malo Apes, Custom Dynamics LED's all around with rear plasma bars.
bisonium is offline
FP3 - The Autotune Process Explained Spazz ECM/Fuel Management systems 103 03-18-2019 10:53 AM
Anyone using the V&H FP3 garbage cannon ECM/Fuel Management systems 23 09-07-2015 08:46 AM
V&H FP3 Value Bundle & Fuel Moto package deals fuelmoto Fuel Moto 0 04-10-2015 11:50 AM
V&H Fuelpak FP3 available from Fuel Moto fuelmoto Fuel Moto 10 03-31-2015 09:13 AM
Vance and Hines FP3 12fltrx ECM/Fuel Management systems 1 09-01-2014 10:45 PM
