Power Vision Troubles - Road Glide Forums
post #1 of 9 (permalink) Old 02-17-2016, 07:55 PM Thread Starter
Brand new PV and it doesn't seem to like my bike.
I hooked up the PV cable to the Diagnostic port on my 08 FLTR and now when I turn the bikes ignition to "ON" I get "BUS ERROR" showing up in the odometer. When I start the bike I automatically get the U1301 DTC in all sections of the Diag except for "P" , U1301 is serial data error.
In the "P" section of the diag I get P0132 & P0152 which is front and back O2 sensors high open. I can understand the O2 sensors may be bad so I order new ones and I am waiting on them, but what I can't understand is these O2 sensors worked when I took them out and installed the Thundermax O2 sensors so why wouldn't they still work when I put them back in and also what is the chance of both O2 sensors going bad at the same time and why would they go bad sitting in the box with the stock ECM.
By the way I am using the stock ECM.
Now for the kicker I UNHOOK the PV data cord at the diagnostic port and everything works just dandy, no more BUS ERROR, no more DTC's but I haven't rode the bike yet so the O2 sensor DTC's may or may not pop up we will have to see. I did try unhooking the PV data cord from the PV module but it didn't do a thing to solve the problem.
Do I have a bad PV data cord? I did run the cord under the dash on the fuel tank as suggested by Fuel Moto and it didn't help a thing either, when riding the bike the PV gauges kept going out and I would have to reset them all the time.
Anyone else have these problems or am I the first?
post #2 of 9 (permalink) Old 02-17-2016, 08:37 PM
Your probably the first. . Subscribed.
post #3 of 9 (permalink) Old 02-17-2016, 09:48 PM
EFI tuning and Exhaust Expert
fuelmoto's Avatar
As I noted in your other thread last week please update your firmware, if you are getting a bus error the newest firmware will 100% take care of your issues. You are welcome to call me tomorrow and i can assist if necessary
Jamie Long / Fuel Moto USA
Contact 920-423-3309
Email
fuelmoto is offline
post #4 of 9 (permalink) Old 02-18-2016, 11:18 AM Thread Starter
I did update the firmware and I just linked the PV module to my PC and checked again and I am currently running the current firmware version.
post #5 of 9 (permalink) Old 02-18-2016, 11:23 AM Thread Starter
Someone has to be the first.
post #6 of 9 (permalink) Old 02-18-2016, 11:36 AM
fuelmoto's Avatar
Email me [email protected] and I will send you the firmware patch that will fix it.
Email
fuelmoto is offline
post #7 of 9 (permalink) Old 02-20-2016, 10:21 AM Thread Starter
I was running the current firmware but Jamie sent me a firmware upgrade which is designed to help with the "BUS ERROR" and U1301 DTC and I installed it and so far so good.
I am still getting the O2 DTCs but less often so I am going to do a few auto tune rides and see if that helps, if that doesn't work I'll put in the new O2 sensors and see what happens.
The folks at Fuel Moto are a great bunch of people to work with.
post #8 of 9 (permalink) Old 02-22-2016, 10:23 AM Thread Starter
Put some miles on the bike this weekend and I am still having problems with the Power Vision. The "Bus Error" doesn't come up when I turn the bike ignition on but I am still getting the U1301 DTC along with the P0132 DTC also getting turn signals and speedometer under the serial data error. Put new O2 sensors in so I took that out of the equation. Also when the Power Vision data cord is unplugged from the bikes data port all the DTC's but the P0132 go away so I am thinking that since the front cylinder is running rich it may be a tune issue.
The good folks at Fuel Moto are looking into the problem.
post #9 of 9 (permalink) Old 03-21-2016, 11:47 AM
Ironmark,
Were you able to get your problem resolved?
bbass is offline
$799 Power Package Street Outlaw mufflers, Power Vision, FM Stage 1 AC fuelmoto Fuel Moto 7 06-16-2018 02:37 PM
LED's, power commander, power vision, and other items for touring models. Gasitman Parts for Sale 5 08-23-2014 12:29 AM
Inner Fairing troubles Mailman Paint & Bodywork Section 20 04-09-2012 12:38 AM
More monkey bar troubles homeboy58 Controls & Handlebars 11 11-21-2011 06:46 PM
Power Command Power Vision problem help! BigDave55 ECM/Fuel Management systems 11 08-06-2011 07:21 AM
