Gas sniffers - Road Glide Forums
 4Likes
post #1 of 31 (permalink) Old 02-25-2016, 06:49 PM Thread Starter
BigNorm's Avatar
Gas sniffers
Are the o2 sensors on our bikes narrow or wide band?
BigNorm is offline
post #2 of 31 (permalink) Old 02-25-2016, 06:49 PM
Smarty's Avatar
Narrow.
2016 RGS Black Quartz
Smarty is offline
post #3 of 31 (permalink) Old 02-25-2016, 06:55 PM
jeff338wm's Avatar
I'm running both.
'13 FLTRX Candy Orange w/ an upgrade here or there
jeff338wm is offline
post #4 of 31 (permalink) Old 02-25-2016, 07:40 PM Thread Starter
BigNorm's Avatar
Cool. I need to figure out what connections do what. I'm wanting to add a pair of O2 sensors.
BigNorm is offline
post #5 of 31 (permalink) Old 02-26-2016, 08:51 AM
Smarty's Avatar
Hey Norm, if your pipes don't already have the bigger bungs, most muffler shops have them in stock. Easy install about 3"s from the heads on the head pipes put in a direction where the sensors clear everything. Cheap to do yourself if you have a big wielder. Good luck.
Smarty is offline
post #6 of 31 (permalink) Old 02-26-2016, 09:40 AM
Your bike already have narrow band O2 sensors which are 12mm so there is no need to add sensors unless you want to go with a auto tune tuner such as a T-max or or PV with the auto tune pro, these style tuners use wideband O2 sensors and the are 18mm.
You can also get 2009 head pipes and install them, the 2009 head pipes have 18mm O2 bungs and no welding is required.
The tuners that have the auto tune and use 18mm wideband O2 sensor usually come with a wiring harness for the O2 sensors.
post #7 of 31 (permalink) Old 02-26-2016, 12:03 PM Thread Starter
BigNorm's Avatar
My idea was to use the stock 02 sensors and hook them up to aftermarket air/fuel gauges. The smarter thing to do would probably be to get some sensors and mount them in the front holes on my rhinehart pipes. I have 2 up top that are currently blocked off and two down below which my stock sensors are in. My stock sensors aren't doing anything because I'm currently running the PCV. I want to get TTS soon so the utilizing the front holes in my pipes probably would be the best option.
BigNorm is offline
post #8 of 31 (permalink) Old 02-26-2016, 12:50 PM
tdkkart's Avatar
I've lost track, does the TTS have any ability to utilize wide band sensors??
tdkkart is offline
post #9 of 31 (permalink) Old 02-26-2016, 02:48 PM
Smarty's Avatar
Not sure, but I don't think so. I think it is like the Direct Link. They utilize the narrow band for fuel/air tweaking for altitude, etc.
Smarty is offline
post #10 of 31 (permalink) Old 02-26-2016, 03:33 PM
tdkkart's Avatar
If that's the case, Power Vison/Target Tune is worlds ahead as it does live wide band tweaking of the map. Works really nice on my 110.
Smarty likes this.
tdkkart is offline
Tank gas question, smell gas Dirty Irish *General Road Glide Discussions/Pictures 3 12-22-2011 03:39 AM
Gas Mileage_ how much? mikesmith *General Road Glide Discussions/Pictures 19 05-26-2011 11:06 PM
smell gas fumes ROADEAGLE ECM/Fuel Management systems 25 02-28-2011 10:30 AM
Gas mileage for Road Glide kimmer127 ECM/Fuel Management systems 77 12-13-2010 12:02 PM
Routing the gas overflow tube kimmer127 Troubleshooting for Road Glides 1 12-05-2009 05:00 AM
