Need Pcv map for 2010 FLTRX - Road Glide Forums
post #1 of 5 (permalink) Old 10-07-2010, 08:27 PM Thread Starter
Anyone have a map for a 2010 Road glide? Iam using a pcv with autotune, D&D fatcat, harley heavy breather, stage 1 download and woods tw6 cams I would really appreciate it! (looking to compare! Especially if you have a dyno map!)
Shane (From Washington)
2010 Road Glide Custom
Axtell 107 (10.6-1 Compression), Pro Street Heads by Dewey, TMAN 590 cams, S&S Roller Rockers, Woods Directional Lifters, Revolution Performance EMS, D&D Boss Fatcat, HD Heavy Breather, Alpine IDA-305s head unit, Boston Acoustic Pro 60SE Speakers, Alpine PDX 2.150 Amp. 116 HP/128 TQ
Various chrome and black bits......
"I've Got A Cobra Snake As A Necktie"
Garcou is offline
post #2 of 5 (permalink) Old 10-08-2010, 09:12 AM
DED HD's Avatar
Where did you buy your PCV? They should provide you with a base map.
I have 2 base maps for the stock exhaust with Nightstick slip on and the Big Sucker Air Cleaner. These were sent from Fuel Moto. I was running too hot with the stock head pipe and the first map they sent me, so they sent me another map that they called a cooling map, running a bit richer.
Cant say whether or not it will help you but PM your email address and I can send them to you.
'10 Red Custom:
DED HD is offline
post #3 of 5 (permalink) Old 10-08-2010, 09:32 AM Thread Starter
Appreciate the offer bud!, Iam specifically looking for the above map (Sancho?)I do have a pretty good base map and my auto tune is working, I want to see and compare maps
Garcou is offline
post #4 of 5 (permalink) Old 10-08-2010, 09:39 AM
DED HD's Avatar
ahhh... I see. no Problem.
'10 Red Custom:
DED HD is offline
post #5 of 5 (permalink) Old 10-20-2010, 05:41 AM
flhr95's Avatar
PCV Map
I thought that buy purchasing the autotune portion of the power commander it either built the map for you or eliminated the need for extra maps.
2010 Fltrx 96", Ness Stage 1 air set-up, V&H Power Duals with Hi Output Slip ons, PCV, SE204 Cams.
flhr95 is offline
Need PCV map Ouijonbu Map Section 0 04-18-2018 12:03 PM
Need map and have map to share Hack73 Map Section 0 10-03-2016 04:42 AM
Need a pcv map 103 with se 204 cam waffler ECM/Fuel Management systems 0 04-30-2016 12:07 PM
Need a 117 base map for pcv tman 625s and worked heads any 117 mapwill work using aut mitchdm ECM/Fuel Management systems 3 05-16-2014 09:31 AM
2011 rgu true duals 57h need PCv map gibrj Map Section 1 09-02-2013 09:18 AM
