fuel pump - Road Glide Forums
post #1 of 11 (permalink) Old 03-18-2016, 03:03 PM Thread Starter
fuel pump
so I changed bars on my 2000 road glide and now it wont start ran the wires internaly all other functions work but I don't hear the fuel pump working. it was fine before can the run kill switch be the problem the wires were tough pulling thro the throttle side , check fuse and the 5 amp em fuse was blowin changed that all other fuses are all right looking thru owners manual but thought I would throw this out there for help
thanks
bigirn is offline
post #2 of 11 (permalink) Old 03-18-2016, 05:09 PM
thanks
Your grounded out some where. Time to back track.
post #3 of 11 (permalink) Old 03-18-2016, 05:31 PM Thread Starter
yea its not firing either going to have to pull the right side back apart . I drew a diagram of the pins before I pulled them out have to double check that as well. gona walk away from it tonight and have a beer thanks
bigirn is offline
post #4 of 11 (permalink) Old 03-18-2016, 06:08 PM
Keep in mind the Fuse
reds4 is offline
post #5 of 11 (permalink) Old 03-18-2016, 06:19 PM
Smarty's Avatar
Just a little tip on pre wiring. Take you phone and take a pic of the connector both from the side whit the notch for locking in place and again for the other side. Really handy and always on your phone. If it's a 15 or 16 I think I still have pics on my phone.
2016 RGS Black Quartz
Smarty is offline
post #6 of 11 (permalink) Old 03-18-2016, 06:20 PM
Smarty's Avatar
Before you pull it out, look at the ends of the wires coming out of the right side handlebars. The pins are really easy to bend over when you are plugging it in.
Smarty is offline
post #7 of 11 (permalink) Old 03-19-2016, 12:42 PM
Sounds like the kill switch, the wires may be damaged somewhere.
Usually if things worked before you did stuff to the bike and then they don't work when you finish then you have to back track your work to find the problem.
post #8 of 11 (permalink) Old 03-19-2016, 03:38 PM
Road dawg's Avatar
+1 with ironmark, im gonna say the wires to that kill/starter switch are frayed and possibly grounded in the bars, sometimes they get caught on the sharp edges or flash from the welding in the bars, def start there, good luck.
Road dawg is offline
post #9 of 11 (permalink) Old 03-20-2016, 12:22 PM Thread Starter
found the problem white with black strip wire was cut in half tracked it back to starter button think its the ground to both on and off switch and starter button. time to break out the old soldering iron
thanks for the help
bigirn is offline
post #10 of 11 (permalink) Old 03-20-2016, 02:22 PM Thread Starter
thanks for the help
so I fixed the wire run back thru the bars instead of mounting the bars I just pluged the harness up for that side , same thing it wil turn over but not start still don't hear fuel pump do I have to assemble every thing to test it.. getting frustrated
bigirn is offline
Fuel Moto 107" hi output R&D motor 151Hp Pump Fuel fuelmoto Dyno Results 5 01-22-2014 08:24 PM
Fuel pump pte359 ECM/Fuel Management systems 7 02-05-2013 11:19 AM
ACR's or Fuel pump,...need answers. Smash.usmvmc Fuel Moto 2 10-24-2012 12:37 AM
Gas tank and fuel pump question jim_b Troubleshooting for Road Glides 3 05-20-2012 12:04 PM
Fuel pump wanted Speedychp61 Classifieds Archive (3 months old+) 0 11-21-2010 10:02 PM
