newb needs a little help... - Road Glide Forums
 2Likes
  • 1 Post By harleytuner
  • 1 Post By Shark daddy
post #1 of 9 (permalink) Old 03-30-2016, 08:24 PM Thread Starter
Hey all, been riding as much as I can trying to get the first 1000 miles done on my 15 RGS. I replaced the slipons with SE highflow and just today did the stage 1 air. I purchased the SE street performance tuner to flash the ecu, (made more sense than taking it to the dealership every time I add a new part), but here's where I'm stuck.
The only applicable map I found lists "103 big bore stage 1 kit"....does anyone have any input on which map to use for my girl?ImageUploadedByMO Free1459387431.338483.jpgImageUploadedByMO Free1459387442.980358.jpg
roadglideruss is offline
post #2 of 9 (permalink) Old 03-31-2016, 06:33 AM
harleytuner's Avatar
The only applicable map I found lists "103 big bore stage 1 kit"....does anyone have any input on which map to use for my girl?Attachment 248857Attachment 248865
The Street Performance tuner is not the same as the Super Tuner. The one you got doesn't have near the options or tuning abilities of the other one.
EODHOG likes this.
harleytuner is offline
post #3 of 9 (permalink) Old 03-31-2016, 06:40 AM
EODHOG's Avatar
Send a message via Yahoo to EODHOG
Not The Same
True. Limited maps and adjustments. None of the "off road only" performance features.
Freedom isn`t free. If you can read this, thank a Teacher. If it`s in ENGLISH, Thank a VET! The right to keep and bear arms shall not be infringed.....
EODHOG is offline
post #4 of 9 (permalink) Old 03-31-2016, 11:01 PM Thread Starter
Yea, I was made aware of that when I bought it. The performance tuner or super tuner would void my warranty I was told. Having only just purchased the bike and the dealership throwing in an extra years worth of warranty (3 total now) I'm reluctant to throw that away. When the warranty is done, I'll look at a better product. I just wanted to squeak out a little bit better performance in the meantime.
I went through all the options for the "tuner" for the stage 1 upgrade and all list the big bore 103 upgrade as the basis for the stage 1. I just want to make sure I'm not going to do any damage by using one of the base maps (high flow exhaust and air intake) which also has the big bore listed.
post #5 of 9 (permalink) Old 04-01-2016, 12:23 AM
EODHOG's Avatar
Afr
As you don't use a map that might be too lean (probably not one of the options you have) you should be good to go. The worst you can do is to get it so rich you'll foul a plug! LOL
EODHOG is offline
post #6 of 9 (permalink) Old 04-01-2016, 01:12 AM
Shark daddy's Avatar
I would take it to the dealer since it is a Harley part and have them set it up.
cookie114 likes this.
"Don't Cheat yourself, Treat yourself"
2015 Superior Blue RG Special
Shark daddy is offline
post #7 of 9 (permalink) Old 04-01-2016, 05:50 AM
I can't be of much help, I don't have any first hand experience with the Street Tuner, I am thinking you can't make any adjustments inside the EPA mandated area, (cruising), I could be wrong.
post #8 of 9 (permalink) Old 04-01-2016, 06:15 AM
'05Train's Avatar
Nothing you do to your bike will void your warranty.
As suggested, if in doubt, take it to the dealer and have them do it.
'05Train is offline
post #9 of 9 (permalink) Old 04-03-2016, 12:16 AM Thread Starter
Thanks guys!! I spoke to the dealer and they said no harm will come using the map supplied that lists the big bore mod. It's running perfect and life is goooood!
Little By Little - Bar Replacement in Process.... JDisMe Controls & Handlebars 19 07-23-2017 10:50 AM
Needs some help please masonc Audio 11 08-22-2011 03:27 AM
Help Needs with TBW Donk *General Road Glide Discussions/Pictures 4 03-15-2011 08:31 PM
Virgin at Daytona Bike Week needs help? Seven3smoke Road Trip Discussions/Stories/Pictures 14 02-02-2011 06:51 PM
New user needs help with engine SLBERRY427 Troubleshooting for Road Glides 10 06-28-2010 07:24 AM
