Thundermax Install - Road Glide Forums
 3Likes
  • 1 Post By ironmark
  • 1 Post By SMOKENJOE
post #1 of 8 (permalink) Old 04-27-2016, 04:00 AM Thread Starter
Thundermax Install
I have a 2007 RG, not mechanically inclined, nor do I know anything about tuning. I bought the ThunderMax for my bike and was wondering if I should install it myself or just take it to the dealership to install it.
If I install it myself, does my bike have O2 sensors? Also, if I plan on upgrading the exhaust, should I just wait until I get the new exhaust?
2007 RG FLTR
dinggus is offline
post #2 of 8 (permalink) Old 04-27-2016, 07:10 AM
RICKLB58's Avatar
Its not that hard of an install, read the directions a couple times, then you will have to decide yourself if your willing and/or able to take this on. BUT definitely I would put the new exhaust on 1st, just remember a thundermax used wide band O2 sensors so you need a 09 or before head pipe or you will have to drill and install larger O2 bungs in a newer model head pipe.
2012 RGU, Thunder Max tuner, V/H power duals, Stage one, DayMakers, 12 inch F47 Malos, custom gages, and some extra chrome.
RICKLB58 is offline
post #3 of 8 (permalink) Old 04-27-2016, 11:42 AM
You can NOT use a 09 head pipe on a 07 bike. Any 08 and 07 exhaust works on the bike and you should already have 18mm O2 sensors on the 07. You will see the O2 sensors on the head pipes about 6 inches away from the cylinder heads.
The T-max is a easy install.
hawwk likes this.
post #4 of 8 (permalink) Old 04-28-2016, 03:09 PM Thread Starter
Don't most pipes now come with 18mm and 12mm bungs?
2007 RG FLTR
dinggus is offline
post #5 of 8 (permalink) Old 04-28-2016, 05:42 PM
SMOKENJOE's Avatar
Originally Posted by dinggus View Post
don't most pipes now come with 18mm and 12mm bungs?
i have bought a few set of exhaust piper some had both 18mm and 12mm you have to plug the set you are not going to use
dinggus likes this.
SMOKENJOE is offline
post #6 of 8 (permalink) Old 04-30-2016, 09:17 AM Thread Starter
Alright, I'll have to find out what the exhaust I have comes with.
2007 RG FLTR
dinggus is offline
post #7 of 8 (permalink) Old 04-30-2016, 12:41 PM
Many aftermarket exhaust head pipes come with 12mm and 18mm O2 bungs.
Your 07 should have 18mm O2 bungs.
dinggus likes this.
post #8 of 8 (permalink) Old 04-30-2016, 02:05 PM Thread Starter
Thanks, I'll wait to install until I get my exhaust.
2007 RG FLTR
dinggus is offline
Thundermax Install Jerkey ECM/Fuel Management systems 3 11-26-2011 12:36 AM
Thundermax on a stock 2010 RGC pab ECM/Fuel Management systems 18 12-22-2010 05:25 AM
Thundermax impression Rowdy ECM/Fuel Management systems 9 11-23-2010 10:27 PM
thundermax TBW roadgliderick ECM/Fuel Management systems 0 11-23-2010 01:36 AM
Zipper Thundermax Ranger58 ECM/Fuel Management systems 12 11-19-2010 11:26 AM
