Can I ride my shark w/o Dino?? - Road Glide Forums
  • 1 Post By bucketlisthd
post #1 of 5 (permalink) Old 05-06-2016, 07:18 PM Thread Starter
Bigvig51's Avatar
I installed a Big Sucker II and Propipe,Then a PCV. If I put in a generic map, can I ride without any damage??
Thanks!
Bigvig51 is offline
post #2 of 5 (permalink) Old 05-06-2016, 07:30 PM
bucketlisthd's Avatar
I bought my Power Vision from Fuel Moto. They sent a map to match my mods. Bike runs excellent.
sh1520 likes this.
bucketlisthd is offline
post #3 of 5 (permalink) Old 05-06-2016, 07:33 PM
TYM2GLIDE's Avatar
Thanks!
I rode my bike with a base map after I installed a new header and A/C, ran well but it ran rich. I had it dyno'd (I have a PCV w/o the auto tuner) because I was tired of smelling gas. The bike ran soother and the gas efficiency increased significantly.
2012 FLTRX, 4" Rineharts, V&H Naked V02, FullSack Head Pipe, 14" Malo's, Topshop Minister Fender & Viper bags, 21in Hogpro Titan wheel, Progressive monotubes with 1in drop, Andrews 57H cams.
TYM2GLIDE is offline
post #4 of 5 (permalink) Old 05-06-2016, 07:52 PM
VikingRider's Avatar
Thanks!
Hi Bigvig; short answer is: yes – you can, but you should consider a dyno-run to reap the benefits of the AC and Propipe.
BTW what model/engine is it?
Your bike was tuned at the factory with the OEM air cleaner and exhaust. With the new set-up your bike is more likely than not running with a lean mixture of air and gas. The engine will run hotter, with a noticeable loss of hp and torque, and with a decel-pop to add insult to injury.
You can't really go wrong with an "official" map and the engine will not take any damage as a result. But tinkering with a "custom map" on your own would be another story. But before any permanent damage occur your engine will sputter and complain, sort of telling you that the demise is near before seizing.
(For the record: I'm not a trained H-D tech but others on here are.)
FLTRSEI2
VikingRider is offline
post #5 of 5 (permalink) Old 05-07-2016, 11:06 AM
Yes you can! A good flash tune will have the bike running just fine with the mods you have.
I Can't Wait I Can't Wait I Can't Wait......The Outdoors SteadyEddie General Off-Topic Discussions 15 05-19-2017 02:57 PM
Can you get Sedona Orange in a rattle can? Gadgetech *General Road Glide Discussions/Pictures 18 01-09-2017 11:34 PM
How can I be so mad over a gas can? FireGuy88 General Off-Topic Discussions 19 01-28-2014 05:02 PM
Rain got in my Dakota Digital Gauges, I guess I can't ride my R.G. in the Rain Bruno3290 Troubleshooting for Road Glides 3 05-22-2011 08:02 AM
Chaincase Oil - Syn back to dino? longrides Troubleshooting for Road Glides 1 05-30-2010 05:09 PM
