What to do with O2 sensor - Road Glide Forums
post #1 of 8 (permalink) Old 05-18-2016, 08:24 PM Thread Starter
I'm installing the auto tune on he pcv and was wondering what people do with the stock sensors? Remove them completely or just let them dangle? I should note i don't have it yet and the pcv is in the box waiting for this weekend. I'm just looking for info in advance.
worst thing to hear in an elevator, ooops I pooped a little!
1shark3 is offline
post #2 of 8 (permalink) Old 05-19-2016, 07:32 PM
RoadGlideGary's Avatar
Remove them. I actually left mine in the stock exhaust when I installed V&H True Duals. Hold onto them as you, or a fellow Tank member, may need them one day. I run a PCV with auto tune on my '08 and love it. Bike runs great with power and mileage. Ride safe!
05' SuperGlideCustom - sold
RoadGlideGary is offline
post #3 of 8 (permalink) Old 05-19-2016, 07:46 PM Thread Starter
Thank you. I've never done this before so i am not sure how accessible the wires for 02 sensors are
1shark3 is offline
post #4 of 8 (permalink) Old 05-19-2016, 08:44 PM
SurlyBoy's Avatar
They're easy to remove. Both wires run back behind the left side cover. You might have to cut a couple of cable ties. You can then unplug them from the base connector just below the top rail
SurlyBoy is offline
post #5 of 8 (permalink) Old 05-19-2016, 08:51 PM Thread Starter
Thanks for the help!!!
1shark3 is offline
post #6 of 8 (permalink) Old 05-19-2016, 08:59 PM
My O2 plugs are both under the right side cover. Yours may be different.
Diverrick is offline
post #7 of 8 (permalink) Old 05-20-2016, 04:26 AM
SurlyBoy's Avatar
I stand corrected. I meant right.
SurlyBoy is offline
post #8 of 8 (permalink) Old 07-08-2016, 03:13 PM
What would be the reason for removing the o2 sensors completely? What is the benefit over the stock ones or going with a wide band o2 sensor?
Cody6590 is offline
o2 Sensor Question InMotionJosh *General Road Glide Discussions/Pictures 8 10-20-2011 03:06 PM
O2 sensor and exhaust help. speedjunkie Intake and Exhaust 3 09-18-2011 06:34 PM
VH Power Duals O2 sensor location Ny Chief Intake and Exhaust 8 08-10-2011 01:54 PM
O2 Sensor removal BadX Intake and Exhaust 5 09-18-2010 06:56 PM
Nightrider O2 sensor - engine heat review joke *General Road Glide Discussions/Pictures 7 09-06-2010 09:26 PM
