Thunder Max and air temp - Road Glide Forums
post #1 of 11 (permalink) Old 06-11-2016, 04:05 PM Thread Starter
BubbaBeef's Avatar
Location: Northern Illinois, where the suburbs end and the corn fields begin
I installed a Thunder Max tuner last weekend on my 2016 FLTRXS, just noticed this issue. Went on a ride yesterday and today, both days the air temp was in the 90's. The ambient air gauge never went about 77. It seemed to be working fine before the install of the tuner. Anyone hear of this problem? Is it a HD issue or a Thunder Max issue? Will erroneous air temp readings cause any performance problems?
Thanks
Panic, chaos, disorder, my work is done here.
BubbaBeef is offline
post #2 of 11 (permalink) Old 06-12-2016, 11:07 AM
Since the T-max is a complete ECM I would say the T-max is the problem. No the ambient air temp malfunction will not affect the way the bike runs so you can either live with it or contact T-max support and explain the problem.
Make sure you are running the latest updates in the T-max module.
post #3 of 11 (permalink) Old 06-20-2016, 07:47 PM Thread Starter
BubbaBeef's Avatar
I got in touch with customer support at Thunder Max, we went through some basic diagnosis. Everything seemed to be OK with the module, it was just giving a inaccurate AAT reading. The last test was to reinstall the OEM module, verify an accurate reading. OEM module gave a good reading, this eliminate a bad senor or loose wire. Thunder Max said they would ship a new module. Yesterday, I took my son on a ride. The AAT reading was correct, WTF? I emailed Thunder Max, we decided to run it for a while and see what happens. Hopefully this will be the end of any issues.
Over all Thunder Max support has been good, thanks Josh!
post #4 of 11 (permalink) Old 06-21-2016, 11:21 AM
PFWiz's Avatar
Wait, are you talking about the thermometer on the dash?
PFWiz is offline
post #5 of 11 (permalink) Old 06-21-2016, 08:12 PM Thread Starter
BubbaBeef's Avatar
yes, that it.
post #6 of 11 (permalink) Old 06-22-2016, 07:37 AM
PFWiz's Avatar
I am 99.9% sure that the Air Temp gauge does not utilize the ECM in any way. Some folks just remove it and install an oil temp gauge in its place....
Most folks think it is useful as tits on a boar hog.
Anyway I am pretty sure that your TM has nothing to do with it.
hawwk likes this.
PFWiz is offline
post #7 of 11 (permalink) Old 05-15-2017, 09:05 PM
hawwk's Avatar
I thought the ECM got the air temp from around the air cleaner and the one in the dash was in the fairing which has nothing to do with the way the bike runs.
hawwk is offline
post #8 of 11 (permalink) Old 05-16-2017, 02:10 PM
SMOKENJOE's Avatar
The air temp gauge is a joke when its hot outside you will know it without that gauge
SMOKENJOE is offline
post #9 of 11 (permalink) Old 05-16-2017, 07:59 PM
Thermodyne's Avatar
The ECM uses a different sensor for intake air temp. The dash gauge has a ambient temp sensor of it own.
No connection between the two beyond battery voltage.
Take that thing out and put a head temperature gauge in place of it.
Thermodyne is offline
post #10 of 11 (permalink) Old 05-16-2017, 09:22 PM
bucketlisthd's Avatar
He's got a RUSHMORE folks. Temperature is part of the Infotainment system.
bucketlisthd is offline
Thunder max problem!!! Help!! Fxdf MenOfFriedland ECM/Fuel Management systems 2 07-19-2013 03:51 AM
Thank you Thunder Max dbell66253 ECM/Fuel Management systems 3 04-25-2012 10:58 PM
Thunder Max? mrmoto95 ECM/Fuel Management systems 10 09-13-2011 12:54 PM
