Tuner question - Road Glide Forums
post #1 of 9 (permalink) Old 07-15-2016, 11:56 PM Thread Starter
emptyking's Avatar
Tuner question
So just got done installing a performance machine fastair cleaner, Vance and Hines 2 into 1 pro pipe and a thundermax. Did everything in directions. When I took it to get gas (after I did everything with the thundermax) I notice a knocking noise coming from the front cylinder. Sounds like an exhaust leak, but I checked for leaks and everything is sealed. I'm not sure if the air cleaner just has a different sound or the exhaust just sounds different. Any help would be great thanks guys.
emptyking is offline
post #2 of 9 (permalink) Old 07-16-2016, 10:28 AM
Smarty's Avatar
If it is an open style air cleaner, what you are hearing is the butterfly flapping. Throttle by wire is bad about this and even cable bikes will do it.
2016 RGS Black Quartz
Smarty is offline
post #3 of 9 (permalink) Old 07-16-2016, 04:13 PM Thread Starter
emptyking's Avatar
Ok thanks. I check the complete exhaust with a smoke test and put a rag over the exhaust and there are no leaks that I can find.
post #4 of 9 (permalink) Old 07-16-2016, 04:38 PM
RoadGlideGary's Avatar
+^ what Smarty said. You will hear lots more from the top end with an open style air cleaner than the stock. Nice group of mods. You should be set for many rides of enjoyment.
05' SuperGlideCustom - sold
RoadGlideGary is offline
post #5 of 9 (permalink) Old 07-16-2016, 05:09 PM
tdkkart's Avatar
Besides holding the air filter, the primary purpose of the stock air filter housing is noise reduction.
One some engines, the noise from the intake is nearly as loud as the exhaust.
tdkkart is offline
post #6 of 9 (permalink) Old 07-16-2016, 05:28 PM Thread Starter
emptyking's Avatar
Wow that crazy. But a much better feeling now that I'm not chasing my tail looking for a leak that's not there. Thanks for the info guys.
post #7 of 9 (permalink) Old 07-16-2016, 06:26 PM
RFG7680's Avatar
My 11 I just traded in was real loud. Crazy loud. Bike was not stock internally.
RFG7680 is offline
post #8 of 9 (permalink) Old 07-16-2016, 07:10 PM Thread Starter
emptyking's Avatar
That just blows my mind. Something I'll have to get used to.
post #9 of 9 (permalink) Old 07-28-2016, 01:02 PM
roadkingcl08's Avatar
My 2011 flhx did it with my fast air intake also, would freak the wife out think the eng was knocking,was annoying for sure,took it off when I traded the street in for my fltrxs, not sure if im going to run it again.......
roadkingcl08 is offline
SERT Tuner Obsolete, Not functioning, Buy new Tuner? hawk06Glide Dyno Results 22 04-04-2016 01:22 PM
SE tuner and Power Vision tuner question bigshaqa *General Road Glide Discussions/Pictures 8 01-11-2015 10:35 PM
tuner no tuner WTH????? motosig102 Intake and Exhaust 19 06-16-2013 03:36 PM
HD Super Tuner vs HD SE Street Perf Tuner mhud3780 ECM/Fuel Management systems 1 02-18-2013 11:00 AM
Warrenty & SE Super Tuner Pro question Dandy1 Road Glide Specific Discussions 11 03-29-2011 08:29 PM
