ECM Flash after Cat Removal - Road Glide Forums
 2Likes
  • 1 Post By PGR
  • 1 Post By NickyNuts
post #1 of 5 (permalink) Old 08-15-2016, 02:38 PM Thread Starter
FeMoRg's Avatar
I have a 2016 RGS and have removed the Cat, Is Flashing or tuning necessary afterwards. Still has stock head pipe and mufflers. I know its been asked many times but couldn't find a definite answer. So I come to the experts.
FeMoRg is offline
post #2 of 5 (permalink) Old 08-15-2016, 03:35 PM
PGR
PGR's Avatar
If the only mod is remove the cat, then a tune is not required. The difference in flow is very slight.
FeMoRg likes this.
Ron..........................
PGR is offline
post #3 of 5 (permalink) Old 08-15-2016, 10:28 PM
NickyNuts's Avatar
You only need to get a retune if you increase the air volume entering the engine. (Adding a high flow air filter) The stock ECM will adjust for the mild increase in exhaust flow when decatting the header, but increasing the air into the engine will dilute the air/fuel mixture beyond the ability of stock ECM to compensate. Therefore, an addition of fuel must be made to keep the air/fuel mixture at the proper ratio. That is what fuel tuners are designed to do. If you decide to add a high flow filter there are plenty of tuners to choose from and just as many opinions on this site as to which one works best based on whatever mods you have.
FeMoRg likes this.
NickyNuts is offline
post #4 of 5 (permalink) Old 08-15-2016, 10:33 PM
NickyNuts's Avatar
post #5 of 5 (permalink) Old 08-16-2016, 08:48 AM
No need to flash or retune, the bikes ECM will make all the necessary adjustments.
Magic Box or Biketronics? or Flash No Flash ? Justposts Audio 28 06-14-2018 07:27 PM
Fuel Moto ECM-E-Flash ?? George W ECM/Fuel Management systems 12 11-08-2016 08:31 PM
To flash or not to flash onemanpossee Audio 13 12-28-2015 12:54 PM
flash no flash???? buddy75 Audio 1 03-20-2015 11:16 AM
ECM flash update scsharp2260 ECM/Fuel Management systems 10 06-10-2011 09:04 AM
