Help a noob (fuel programmer) - Road Glide Forums
 2Likes
  • 1 Post By Headrope
  • 1 Post By GusEmery
post #1 of 3 (permalink) Old 08-17-2016, 02:12 AM Thread Starter
Headrope's Avatar
Couple of questions:
How do I know if there is a fuel controller on my bike? Where do I look for it/what would it look like?
I'm presuming that by disconnecting the battery I am going to lose whatever tune/program is on the bike. Is there something I can do first to save myself from needing a dyno tune?
Sorry for the noob questions. I was a carb guy before getting a 2010 'Glide. I bought it used, might need a new battery and am new to Harleys so could use some help.
Chrisg81983 likes this.
Headrope is offline
post #2 of 3 (permalink) Old 08-17-2016, 04:32 AM
GusEmery's Avatar
Send a message via Skype™ to GusEmery
There are a couple of different programmers that would be on your bike.
1) Add on
2) ECM Reprogrammer
Neither should lose a tune if you disconnect the battery
If you have the add-on, it should be plugged into the 'ECM' which is attached above the battery. These add hardware onto your bike.
If you have the ECM reprogrammer, it would have come with the bike. They are 'married' to the ECM, and can't be re-used. These just re-program the factory ECM, the nice thing is that you don't need to have additional hardware on your bike, that can stop working, and then your bike would then die, or go back to stock tune, which could be really bad IF you have a cam in the bike.
Most bikes out there would most likely have a 'HD' tune, or a tune that is downloaded from the dealership. These are usually very LEAN and run hot.
Anyway, hope this helps!
GusEmery is offline
post #3 of 3 (permalink) Old 08-17-2016, 05:56 AM
mocotom's Avatar
Like Gus said, you will not lose a tune by disconnecting the battery with any tuner. You can check the bike's serial number at your Harley dealer, if any dealer changed the ECM calibrations it will be noted.
2005 RG 98cu in
USMC 1968-1972
mocotom is offline
Help a noob (think I need a battery) Headrope Do-IT-Yourself 17 08-22-2016 05:11 AM
Can you have duals w/o programmer custhar1 Intake and Exhaust 7 08-26-2012 08:36 PM
Programmer Rattbone ECM/Fuel Management systems 4 05-13-2012 12:41 PM
Getting real close- help a noob allay some fears! Govdog76 *General Road Glide Discussions/Pictures 24 02-07-2011 02:18 PM
