Tuner advice needed - Road Glide Forums
 2Likes
post #1 of 20 (permalink) Old 08-29-2016, 07:42 AM Thread Starter
Tuner advice needed
Getting an Arlen Ness Big Sucker and V and H Pro Pipe on my 2015 FLTRXS. Dealer wants to put a Screamin' Eagle Pro Street Tuner
Part Number 41000008C
Screamin' Eagle Pro Street Tuner | Specialty Tools | Official Harley-Davidson Online Store
on the bike for me. Says if I do any other tuner it voids the warranty.
Is this tuner any good? Would it be much better to get a different tuner? My warranty is up in March anyway. I'm doing the pipes and air cleaner tomorrow.
palmpalm is offline
post #2 of 20 (permalink) Old 08-29-2016, 08:01 AM
GusEmery's Avatar
Send a message via Skype™ to GusEmery
Ugh, more warranty crap..
There are a TON of tuners out there. Harley is forced now to run EPA friendly. Not that it is TOTALLY a bad thing, however it may run very lean and hot compared to a well running engine. That being said, it's not a bad tuner. I prefer the TTS Mastertune, and others have their favorites. All will update your ECU and make the 'Stage 1' work better.
I'm sure more people will chime in.
-G
GusEmery is offline
post #3 of 20 (permalink) Old 08-29-2016, 08:22 AM
SteadyEddie's Avatar
ANY Tuner installed will Technically void your warranty ........ he is trying to scare you into buying from him.
As for the Street Tuner, it is okay and how explained to me, "Comes with a predefined map loaded and does not allow for granular tuning" - That being said, it is okay and for $250......it is okay if you want it done and never plan to do more than a Stage 1 - If you want to grow past that, I would consider other options
SteadyEddie is offline
post #4 of 20 (permalink) Old 08-29-2016, 08:56 AM
Desertwndrr's Avatar
TTS. Best tuner out there. Allows you to adjust every aspect of your ECM from speedometer on up.
2019 RGS, 2016 RGS, 2015 RGS
Desertwndrr is offline
post #5 of 20 (permalink) Old 08-29-2016, 09:00 AM
gorillaman's Avatar
Hands down... Best tuner on the market is and has always been the ThunderMax.
That's why its expensive. Harley was going to use it for their SERT but was cost prohibitive.
Now HD are in trouble with installing factory tuners (SERT etc) because of EPA etc.
The only "Void" on Warranty is if they can absolutely confirm that whatever part you are claiming under warranty was caused by the aftermarket ad-on.
For example.... if your starter or Stator go bad and you have a ThunderMax tuner... It's not the Tuner that caused the failure so you are covered...
2016 FLTRU Vivid Black
gorillaman is offline
post #6 of 20 (permalink) Old 08-29-2016, 09:05 AM
'05Train's Avatar
TTS or Power Vision. You keep the excellent Delphi ECM and it's knock sensing (unlike the Thunder Max), and there's no add-ons on the bike (unlike the piggyback tuners).
SharknoseScott and GusEmery like this.
'05Train is offline
post #7 of 20 (permalink) Old 08-29-2016, 09:34 AM
BlazingSaddle's Avatar
Yep, just what SteadyEddie said. I think your question is do aftermarket tuners void the warranty. You'll get several different answers on that. I haven't read or heard anywhere where warranty work was denied because of a tuner but doesn't mean those cases don't exist. You do take your chances. The training tutorial for the Screaming Eagle Pro Super Tuner (a different tuner than what you're looking at) specifically stated it voids the warranty. As an FYI to those who've been following this tuner fracas, it looks like what used to be called the Screamin' Eagle Street Performance Tuner $249 (only just a week ago and now no longer available) is now called the Screamin' Eagle Pro Street Tuner $299 not to be confused with the Screaming Eagle Pro Super Tuner which was the subject of scrutiny and also no longer available thru HD. Are there better tuners than what you're looking at? You betcha and every one has their preferences. If all you're ever gonna do is a Stage 1, a $600 tuner isn't really necessary.
BlazingSaddle is offline
post #8 of 20 (permalink) Old 08-29-2016, 09:56 AM
transdude's Avatar
I went with Ness Big Sucker, a Black ProPipe and FP3 I decided on this because I got great package discount from company in PA for $1059 total. Did the work myself and bike runs much better and sounds great FP3 so easy to work with and if I go to competition baffle I can tune for it. I have not auto tuned yet been too busy riding 7,500 miles in 3 months.
2016 FLTRX Denim Black; V&H black Propipe; FP3, Ness Big Sucker Intake!
transdude is offline
post #9 of 20 (permalink) Old 08-29-2016, 10:08 AM
ERod62's Avatar
Another for TTS and PV but will say use what the shop tuning your bike recommends since they are the one working on it. Don't force something they don't know how to work on.
PV is easy to use and lots of maps available from wich can start from then running auto tune will finalized.
We will see dealers using screaming eagle only on HD mods.
ERod62 is offline
post #10 of 20 (permalink) Old 08-29-2016, 10:21 AM Thread Starter
FP3 good enough?
Thanks for all the replies guys.
Would the VandH FP3 be good enough to make my bike run right with this set up? Better than the Screamin' Eagle Pro Street Tuner that the dealer wants to give me?
palmpalm is offline
tuner no tuner WTH????? motosig102 Intake and Exhaust 19 06-16-2013 02:36 PM
HD Super Tuner vs HD SE Street Perf Tuner mhud3780 ECM/Fuel Management systems 1 02-18-2013 10:00 AM
Advise on dyno tuner & engine builder needed neuropac Engine Related 7 11-16-2012 10:18 AM
Why is a race tuner needed for a Heavy Breather/Slip on combo? Trevor ECM/Fuel Management systems 13 03-04-2012 11:33 AM
2010 FLTRX w/stage 1 (stock headers) - is a "tuner" really needed? 4getNo1 ECM/Fuel Management systems 27 10-28-2010 03:20 PM
