Thundermax vs DynoVision vs PwrPro Black vs FP3 - Road Glide Forums
View Poll Results: Which autotuner should I get?
Thundermax 17 36.96%
PowrPro Black 0 0%
FP3 14 30.43%
DynoVision 13 28.26%
PowerCommander 5 w/autotune 2 4.35%
other 1 2.17%
Multiple Choice Poll. Voters: 46. You may not vote on this poll
 2Likes
post #1 of 17 (permalink) Old 09-09-2016, 04:41 AM Thread Starter
I have a 2015 CVO Road Glide Ultra. I will soon be installing a Figure Machine TCFLOW-VISION 5 - TWIN CAM AIR CLEANER and a KessTech 2-into-one exhaust system. As far as I know, neither one of these products or companies are very popular so I doubt they will be on any list to get specific maps for any of the EFM systems out there. Hence, I am leaning towards an autotune system. Not only the off-name brand parts but the fact that, being in the military, I move around a lot and the autotune would work best with my bike being in different environments all of the time without having to get it dyno'd or remapped every time I move. I am just curious which model I should go with. Every one of these systems claims to be the best one on the market. That is obviously not possible. I'm sure that each one is best for different bikes and different set-ups. Any gearheads out there that may happen to know what the best set-up for my bike would be? Thank you!
stillsoldier4christ is offline
post #2 of 17 (permalink) Old 09-09-2016, 09:48 AM
tdkkart's Avatar
Assuming that DynoVision means Power Vision.........
A bunch of people are going to be upset you didn't include TTS.
tdkkart is offline
post #3 of 17 (permalink) Old 09-09-2016, 10:30 AM Thread Starter
What is TTS?
post #4 of 17 (permalink) Old 09-09-2016, 10:35 AM Thread Starter
Is there a way to edit the poll to add TTS?
post #5 of 17 (permalink) Old 09-09-2016, 10:35 AM
With the mods your doing a flash tune from the dealer should work well but if you want to go with a tuner and flash tune the bike yourself the the Power Vision should be your choice, the Thundermax works better for bigger performance builds IMO.
I used both the Tmax and the PV.
post #6 of 17 (permalink) Old 09-09-2016, 10:38 AM Thread Starter
Thumbs up
I do have future plans. Eventually, I will upgrade to the 117ci kit and upgrade cams, and who knows what else....?
post #7 of 17 (permalink) Old 09-09-2016, 11:00 AM
You can get the Power Vision flash tuner and use it to flash tune the bike and it also has a auto tune feature that uses the stock 02 sensors. Then if you want to go with a bigger performance build later on you can get the Auto tune Pro kit and hook it up to the Power Vision that you already have
A true auto tune system uses the 18mm 02 sensor that read the AFR in real time and it will keep the AFR in it's set parameters. Remember a auto tune no matter who makes it will not auto tune the engine timing, all engine timing adjustments has to be done manually.
post #8 of 17 (permalink) Old 09-09-2016, 07:04 PM
If you're sure you're going to upgrade, the TMax is a great system, I'm on my second bike with a TMax and have really been happy with it. One of my current bikes started life as a 96 and is now a 107, the TMax has been great. If you end up going that route check with Frank at Dragos for the best price. BTW, my other bike is a 16 with the FP3, I'm happy with it also and it's super simple to install and use. I have no intention of doing more than maybe a mild cam on this bike, so the FP3 is perfectly suitable.
dbell66253 is online now
post #9 of 17 (permalink) Old 09-11-2016, 01:03 PM Thread Starter
HMMM, guess NOBODY likes the powercommander or the Cobra...
post #10 of 17 (permalink) Old 09-11-2016, 01:39 PM Thread Starter
So, I think I have decided on the Power Vision. $429 on Amazon. Anybody know of a cheaper place to buy? Thanks!
Thundermax vs FP3 Shaner87 ECM/Fuel Management systems 11 04-08-2016 05:48 PM
Anyone using the V&H FP3 garbage cannon ECM/Fuel Management systems 23 09-07-2015 09:46 AM
V&H FP3 Value Bundle & Fuel Moto package deals fuelmoto Fuel Moto 0 04-10-2015 12:50 PM
V&H Fuelpak FP3 available from Fuel Moto fuelmoto Fuel Moto 10 03-31-2015 10:13 AM
Vance and Hines FP3 12fltrx ECM/Fuel Management systems 1 09-01-2014 11:45 PM
