PV Install - Road Glide Forums
post #1 of 6 (permalink) Old 02-03-2013, 05:08 PM Thread Starter
bigcletus's Avatar
PV Install
How much work, and how complicated is it, to run the PV cable to the handlebars? I have a handlebar mount on its way and wondering whats involved...i.e. remove the tank ?? etc..
Thanks
2007 Road Glide FLTR
bigcletus is offline
post #2 of 6 (permalink) Old 02-03-2013, 05:33 PM
Crazylegs's Avatar
Some guys go under the console on the tank.
Crazylegs is offline
post #3 of 6 (permalink) Old 02-03-2013, 05:44 PM
Triplej's Avatar
Its a pretty easy job. Check out the install instructions from Iron Aces for their isimple IS75 Cable kit. The procedure is the same just using the PV cable instead. Don't let pulling the fuel tank worry you, it is not that difficult even with a tank that is not empty.
http://www.ironacesspeedshop.com/pro...tion-guide.pdf
Triplej is offline
post #4 of 6 (permalink) Old 02-03-2013, 07:18 PM
jack6hd's Avatar
+1 for tank not being difficult. Pulled mine and put the cable inside the wire caddy. I ran the cable up the left side handle bar next to switch wires.
2015 FXDL 2nd best HD on road
jack6hd is offline
post #5 of 6 (permalink) Old 02-03-2013, 07:29 PM
elbohead's Avatar
Under the tank console took about 5 minutes. Plenty of room and you'll end up with lots of slack to mount anywhere on the front end.
2012 FLTRX, BBP, 13" MadStad, Fuel Moto Pro Billet AC and 4" Dyno Tuned Jackpots, catless header, DinoJet Power Vision, Horizon Helibars, Iron Aces mount, HD Aileron grips, Ward's cooling fans, Mustang Wide Tripper solo, CD Plasma Rods and LED turns...
elbohead is offline
post #6 of 6 (permalink) Old 02-03-2013, 07:43 PM
I would encourage you to take what little time and trouble it takes to pull the tank, and route the wiring in the cable trough above the backbone of the frame. I cheated at first, and simply zip tied mine to the underside of the backbone...bad move. My PV would intermittently lock up, while data logging. One call to Jamie fixed that! I described what was going on, and he immediately asked how I'd routed my cable to the PV module. Putting it near the plug wires(like I did) will cause interference, and lock it up. Pulled the tank, re routed the cable in the raceway above the backbone, and trouble free ever since! Another lesson to avoid shortcuts, and do it right the first time!
Jeff
akjeff is offline
New 16 FM Jackpot-PV Install chriscalabro Fuel Moto 3 10-08-2016 11:43 PM
Instructions for Dyno-jet and PV install? StriderJim ECM/Fuel Management systems 1 04-20-2013 08:26 AM
Sest, PCV or PV Bobbyl ECM/Fuel Management systems 19 11-04-2012 03:03 AM
Pv,rineharts,2-1-2 fuel moto are shipped Jesse_the_kid Intake and Exhaust 2 04-20-2012 07:52 AM
PV question? roaddog ECM/Fuel Management systems 2 02-24-2012 07:03 PM
