PCV- Setting Throttle Position Voltages - Road Glide Forums
post #1 of 9 (permalink) Old 02-07-2013, 02:20 PM Thread Starter
X In Black's Avatar
Exclamation PCV- Setting Throttle Position Voltages
Working with DynoJet on my map because of some popping during shifting. So yesterday he had me set the 0% throttle position. Well that ended up setting the 100% number very close to the 0%, so with just a small blip of the throttle, the program would go straight to 100% throttle.
Today, he wants me to set the 100% throttle position, too. The Help file says do not crack the throttle to 100% on Throttle by Wire (TBW) motors unless you are on a dyno. I mentioned this and he said plenty of people do it. He did say the base numbers for that model are 0%= 0.770 & 100%= 4.300. Is this safe or is there another way? Just set it to 4.300?
2012 FLTRX
Rinehart 2 Into 1|Ness Big Sucker AC|Andrews 57H Cams|PowerVision
X In Black is offline
post #2 of 9 (permalink) Old 02-08-2013, 07:43 AM
Eshaw301's Avatar
Avoid all this headache and just get the Autotune module.
"DUDE!...Your exhaust is making the ground shake!" Circa March 2014, Born Losers MC, Atlanta.
Eshaw301 is offline
post #3 of 9 (permalink) Old 02-08-2013, 07:52 AM Thread Starter
X In Black's Avatar
Agreed. I知 planning getting a Power Vision soon, but for right now, I知 just trying to get the bike to run a bit better. I did the 100% Throttle Position setup last night. Not a big deal if you twist it fast and let it go. The voltage jumped right up to 4.642, and I hit OK to set it. Runs better with the new map, but I知 calling them back today to help get rid of some decal pop.
2012 FLTRX
post #4 of 9 (permalink) Old 02-08-2013, 09:28 AM
EFI tuning and Exhaust Expert
fuelmoto's Avatar
On drive by wire models you cannot reset throttle position without having the bike on a dyno and the ability to put the bike under load. If you it reset even if you open the throttle quickly it will not be correct because the throttle blade is not proportional to the twist grip. To fix this go to Power Commander Tools/Calibrate/Throttle Position and manually enter these values: Min .7 Volts/ Max 4.3 Volts. You can start the bike and watch the "current" voltage and put it in "minimum" and you will be good to go.
For your decel popping I would go into each fuel table an at 10% in the 0% column from 1750-5000 RPM's, send the map and give it a try.
Jamie Long / Fuel Moto USA
Contact 920-423-3309
Email
fuelmoto is offline
post #5 of 9 (permalink) Old 02-08-2013, 09:55 AM Thread Starter
X In Black's Avatar
Thanks, Jamie, really appreciate it. I think I値l call you this afternoon and go ahead and order the Power Vision. Maybe I can talk you out of a better map for my PCV to run while I知 waiting for the Power Vision to show up .
2012 FLTRX
post #6 of 9 (permalink) Old 02-08-2013, 10:46 AM
fuelmoto's Avatar
We would be happy to help out
Email
fuelmoto is offline
post #7 of 9 (permalink) Old 02-08-2013, 11:04 AM
Speedie's Avatar
Jamie, the PowerVision has been an amazing tuner for my bike. I love it.
I sent over a Canadian friend from another delphi forum your way to pick up the same. I think he ended up getting the power package. I know he's going to be very happy.
2015 Road Glide Special
Detachable Trunk : Detachable Passenger Back Rest
Rinehart Exhaust : De-Cat Headers : J&M 330W Rokker Amp and Speakers
Speedie is offline
post #8 of 9 (permalink) Old 02-08-2013, 01:31 PM
faststan's Avatar
Thumbs up
I am very pleased with the Power Vision I got from Fuel Moto.
When I got it I had cams installed with a new 2:1 Rush exhaust. The indy who did the install got the O2 sensors hooked up backwards and told me it runs great. On the way home it started popping and missing. My first thoughts were "I supplied the parts so it is my problem to figure out". After finding the O2 sensor problem, I switched them and took the bike for a ride. Still some popping but no missing. I turned on Basic Autotune and went for a ride in all 'normal for me' situations. When I got home I saved the tune and downloaded the autotune map.
Bike runs fantastic, no popping, no missing, just GOOOOOOO. Great product.Basic Autotune saves a lot of head scratching and repeating new words I learned.
JMO.
11 FLTRU 103 Red Hot Sunglow
faststan is offline
post #9 of 9 (permalink) Old 02-08-2013, 01:44 PM Thread Starter
X In Black's Avatar
Just hung up with Fuel Moto and ordered a Power Vision. Hopefully a new map for my PCV will show up today so I can run it over the weekend. Sunny and high 70's all weekend here in Florida. Sorry, Northeast...
2012 FLTRX
Very loud clank when shifting or getting on throttle or letting off throttle Callahan69 Engine Related 28 11-14-2016 01:09 PM
Throttle position sensor question AnCap Controls & Handlebars 0 09-18-2015 06:32 PM
Throttle Position Sensor GOSKERZ Troubleshooting for Road Glides 9 06-17-2012 08:03 AM
Need help setting up my wife's Road Glide NCTim *General Road Glide Discussions/Pictures 5 11-09-2010 11:27 AM
Setting it up the way I want it. DwayneInfo Aftermarket Accessories 8 03-23-2010 05:55 AM
