Is gas tank removal necessary for EFI kit - Road Glide Forums
 4Likes
  • 3 Post By calgaryglide
  • 1 Post By gorillaman
post #1 of 8 (permalink) Old 09-29-2016, 11:57 AM Thread Starter
Question Is gas tank removal necessary for EFI kit
I bought the Screamin' Eagle Stage 1 Kit for EFI models for my 2016 Road Glide Ultra, along with the Vance and Hines FP3 Fuelpak, intending to do the install myself. The instructions for the EFI Kit say:
1. Remove Main Fuse
2. Remove air cleaner cover and discard remaining parts.
3. Remove Fuel Tank.
My question: Is it really necessary to remove the fuel tank? If so, I may be taking this to the dealer. Lake Shore Harley north of Chicago quoted $294 to install the EFI Kit and do the initial set-up of the FP3 Fuelpak.
Thanks, Dave
dsmith76 is offline
post #2 of 8 (permalink) Old 09-29-2016, 12:04 PM
You shouldn't have to remove the tank, I believe they say to do so only to make everything more accessible .
RoGlide510 is offline
post #3 of 8 (permalink) Old 09-29-2016, 12:29 PM
calgaryglide's Avatar
Hello Dave,
The fuel tank is actually very easy to remove. First thing to do is ride it until you've used up most of your fuel and get home with less than a 1/4 tank of fuel. This is the most fun part about any mod that requires the fuel tank to be removed. I would suggest riding someplace for good bbq or your favorite type of food / entertainment establishment then return home. Let your bike cool down before doing anything to it. There is far less chance of personal injury (being burned). Lastly an empty fuel tank weighs far less than a full one.
I would also suggest picking up a service manual for your year of bike. The instructions in the manual are clear and simple, from what I can remember, no special HD tools are required to remove the tank from the bike.
Believe me, if I can do it, anybody can. Save the labor costs of the dealer tech and do it yourself. It will give you much satisfaction to work on your own bike.
Some things to have on hand when you do want to tackle this easy modification
1. Good bench or table that you can lay out parts on as you take them off. I usually like to cover that bench or table with a moving blanket, this is where I will place all painted or chrome parts that come off
2. Ziplock bags, sandwich size. I put all small hardware fasteners in a zip lock bag and label it for what they attach, e.g. fuel tank bolts or saddle bag bolts or tank dash bolts; especially if I know that I won't be able to complete the job in one session.
3. Good selection of basic tools that are used on a Harley, Allen wrenches, regular and deep 3/8" drive SAE socket set comes in handy, Torx screwdrivers and or bits.
4. Torque wrench in in/lbs and ft/lbs. All torques for all fasteners on your bike are listed in the back of the service manual. There is no excuse for "over tightening" a fastener
5. Patience, patience, patience. This virtue will serve you best.
You can do it and you should do it for these easy modifications. This is the best way to get to know your bike and the satisfaction of doing it yourself will lead you to do more and more work on your bike building your confidence in your own mechanical abilities.
Calgaryglide
madmat, Swomack and gorillaman like this.
2019 FLTRU, Tyggr
calgaryglide is offline
post #4 of 8 (permalink) Old 09-29-2016, 12:37 PM
gorillaman's Avatar
I agree... Removing the gas tank is really easy... The quick release fuel line is simple and then there are only a few bolts and you are done...
Swomack likes this.
2016 FLTRU Vivid Black
gorillaman is offline
post #5 of 8 (permalink) Old 09-29-2016, 02:35 PM
James's Avatar
I removed the tank the last 3 times I have worked on the bike. It now takes less than 10 minutes including finding my tools in my mess of a tool box. It's a sure way to minimize scratches or dents while installing bars or working anywhere near the tank.
James is offline
post #6 of 8 (permalink) Old 09-29-2016, 08:14 PM
BH#103's Avatar
1. Remove Main Fuse
Thanks, Dave
If you are going to Lake Shore you are in my neck of the woods. Save your money and do it yourself, if you need help let me know.
"SLIVER"
BH#103 is online now
post #7 of 8 (permalink) Old 12-25-2016, 10:14 AM
RoadGypsy's Avatar
Removing the tank to install the Stage 1 makes it much easier. I was worried, but broke out the manual. Was easy. I installed the bracket with the wrong screws and had to remove the tank a second time.
Save your money and do it yourself.
It doesn't matter, as long as you ride.
RoadGypsy is offline
post #8 of 8 (permalink) Old 12-25-2016, 11:38 AM
Desertwndrr's Avatar
As discussed, the tank is easy to remove. That said, you actually do not need to remove the tank. It is only referenced to remove the tank to unscrew the two bolts holding the throttle support bracket in place. It is tight, but you can do it with a 3/16" Allen wrench. It's even easier with a ratcheting Allen wrench.
2019 RGS, 2016 RGS, 2015 RGS
Desertwndrr is offline
Gas Tank removal video- late model touring SteveH Do-IT-Yourself 9 04-29-2016 07:59 AM
Wtb!!! Efi gas tank and pump BlackDangerous Parts for Sale 0 06-18-2015 06:10 PM
Won't Start After Gas Tank Removal / Install BigThunder *General Road Glide Discussions/Pictures 7 10-15-2014 09:19 AM
Tank gas question, smell gas Dirty Irish *General Road Glide Discussions/Pictures 3 12-22-2011 04:39 AM
gas tank removal burnah Do-IT-Yourself 9 11-16-2011 05:15 AM
