HD Super Tuner vs HD SE Street Perf Tuner - Road Glide Forums
post #1 of 2 (permalink) Old 02-16-2013, 11:54 AM Thread Starter
mhud3780's Avatar
What is the difference between these 2? The Super Tuner is 459 and the SE Performance tuner is $249. I'm planning add ons for a 2013 RG ultra with 255s and 2/1 exhaust. Thanks
mhud3780 is offline
post #2 of 2 (permalink) Old 02-18-2013, 10:00 AM
UltraNutZ's Avatar
the street tuner only allows you to download and flash maps generated by HD, same crap as a stage 1 download from a dealer. Do not waste your $ on this device! The SEPST is a full blown tuning device that gives you full (well as full as full can get with SE products) access to your ECM to modify maps and flash to your ECM.
There are other products out there that do this as well, some better, some worse. Some of the more popular ones are the TTS and Power Vision.
Ultimately if you're going to have your biked tuned by someone, then you should ask them what they want to tune your bike with and go with that. If you're going to "tune" it yourself, the TTS or Power Vision are the way to go. They both provide DIY tuning methods.
If you don't want to "tinker" once everything is set, then I wouldn't spend the $ on the full tuners like this. Call Jamie @ Fuel Moto, order a Micro Tuner or PCV, tell him what build you have and he'll preload a map for you on the device when he sends it to you. From there you simply plug it in, and ride. If you change something up later, call FM back and tell them what you changed, and they'll send another map to your via email for your device.
2012 FLHTK - VTPBB
UltraNutZ is offline
SE Super Tuner or TTS Xaran ECM/Fuel Management systems 12 07-13-2011 11:27 PM
So I got a used SE Pro Super Tuner... ScooterDog ECM/Fuel Management systems 27 07-01-2011 07:00 AM
Anyone using SE Pro Super Tuner? Wharf Rat ECM/Fuel Management systems 6 04-22-2011 09:15 PM
Warrenty & SE Super Tuner Pro question Dandy1 Road Glide Specific Discussions 11 03-29-2011 07:29 PM
SE Super Tuner software abone ECM/Fuel Management systems 6 03-22-2011 12:19 PM
