Thundermax trouble - Road Glide Forums
post #1 of 12 (permalink) Old 02-25-2013, 07:59 AM Thread Starter
Hullhorr's Avatar
Thundermax trouble
Installed my new Thundermax this weekend and went for a spin yesterday. The engine light came on right out of the gate and never went off.
Yes, I did the proper initializing procedure per the installation guide. It came loaded with a map so the bike was actually running fine. Rode it for about 50-miles and put it back in the garage. Checked the error codes and there were about 15 of them. I wrote them all down, but do not have them with me. I was able to clear all but 1 of them. The P0134 code will not clear. This is the front O2 sensor.
I'm going to try resetting the system tonight and see if I can get it to go away before calling Zippers. I'm curious if anyone else has had this problem with theirs. I found one thread with a similar problem, but no solution was ever posted. I'm only about a half hour from Zipper's place so I may arrange to take the bike to them if possible.
One other thing I noticed yesterday was when I turn the ignition switch on the fuel pump has a 1 to 2-second delay before it comes on. With the stock ECM it was instant. Is this normal?
Update: I got home and pulled the fuse, disconnected the battery, pulled the front and rear O2 sensor connectors apart and put dielectric grease on them. The instructions did not say to use dielectric grease on those but I read where others did so I figured it couldn't hurt. I did the initializing procedure again and we appear to have a winner. The engine light went out. I'll try and take it to work tomorrow and see how it does.
I did not plug the laptop into the unit this time. That is the only thing I did different from the first time.
2009 FLTR MOP
Hullhorr is offline
post #2 of 12 (permalink) Old 02-25-2013, 08:20 AM
Boss Ross's Avatar
Thundermax trouble
I would all zippers. I didn't have much trouble with mine. Don't be discouraged though, it could just be a bad unit.
Sent from Motorcycle.com App
2012 RGC Big Blue Pearl
103" D&D Fat Cat
Thundermax Tuner
SE Ventilator air cleaner
Boss Ross is offline
post #3 of 12 (permalink) Old 02-25-2013, 08:20 AM
Boss Ross's Avatar
Thundermax trouble
Sorry I meant call.
103" D&D Fat Cat
Thundermax Tuner
post #4 of 12 (permalink) Old 03-07-2013, 10:15 PM
SIG556's Avatar
Got to use the grease!
I had a problem with mine as well, put the grease on and it went away. Also had the dealer install new bars and got the throttle code... cleared that.
Ron
Back In Black!
SIG556 is offline
post #5 of 12 (permalink) Old 03-08-2013, 07:11 AM Thread Starter
Hullhorr's Avatar
I'm not sure what went wrong on my first go round, but I am going to chalk it up to something I did wrong. It is working great now.
I am curious if anyone else running the Thundermax has a slight delay in the Fuel pump kicking on. With the stock ECM it was instant when you turned the ignition on you immediately hear it. I get a slight delay before it kicks on now.
2009 FLTR MOP
Hullhorr is offline
post #6 of 12 (permalink) Old 03-08-2013, 08:04 AM
Flexin's Avatar
Thundermax trouble
I would have them test the unit and sensors (connections). Although the grease is a good thing to apply you should not need it with a brand new unit. Their customer service is very good.
A faulty unit is nothing to take lightly especially if it fails many, many miles from home..
Let us know what they say....
Flexin is offline
post #7 of 12 (permalink) Old 03-08-2013, 12:18 PM
Boss Ross's Avatar
Thundermax trouble
I have the fuel pump delay, it doesn't bother me though, I really don't notice it.
103" D&D Fat Cat
Thundermax Tuner
post #8 of 12 (permalink) Old 03-08-2013, 02:11 PM
adam_twenty6's Avatar
Re: Thundermax trouble
My fuel pump has a split second delay, but I don't really notice it any more.
2008 FLTR 105th. thundermax, rinehart true duals, custom paint, K&N High Flow, BAL tail light, 2+2 bars, -1 rear, Hawg Wired and RF Audio, avon grips and more $hit the wife don't know about, for now....
adam_twenty6 is offline
post #9 of 12 (permalink) Old 03-08-2013, 04:28 PM
tsmartt's Avatar
Thundermax trouble
Depending on when your unit was loaded, you may need to do a firmware update. I put my TMax on in December. I checked for an update because of a starting issue and got the latest version installed. Rode 50 miles today and the bike ran great. They also updated my map (#273) and got rid of the old map (#236), so something was not working properly. Their support is awesome along with a lot of information online. Good luck.
Quattro / 16 RGS / Dragula2 2:1 / Drago 565 / ThunderMax Tuner / Fuel Moto Breather / Klock Werks Flare / Custom Dynamics LEDs
Orange Crush / 13 RGC / Dragula 2:1 / TMan 555TQ / ThunderMax Tuner / Zipper's Max-flow Breather / Klock Werks Flare / Custom Dynamics LEDs
tsmartt is offline
post #10 of 12 (permalink) Old 03-08-2013, 07:19 PM
xrwoody's Avatar
Greased all connectors before I ever put unit on bike (always a good if you ride in the rain).Thundermax works flawlessly, never have any problems. I thought the fuel pump delay was just me, I have it also.
Woody
xrwoody is offline
How to Find your Diagnostic Trouble Codes ironmark Troubleshooting for Road Glides 42 05-03-2019 06:43 AM
Trouble receiving Yaffe parts? Neano62 *General Road Glide Discussions/Pictures 5 04-02-2011 05:16 PM
Electrical Trouble twr05 Troubleshooting for Road Glides 11 03-24-2011 12:59 PM
Trouble with the dealer. BDMastiff *General Road Glide Discussions/Pictures 31 12-03-2010 04:45 PM
Signature Pic Trouble Rottiman *General Road Glide Discussions/Pictures 5 06-28-2010 11:50 AM
